i want an electric fan!!!info needed
Old Mar 15, 2003 | 10:39 PM
i did a search and got some info!!! but wanted to know how easy the swap is!!! and i have an 85 12a with stock radiator will a 16 inch fan fit???? or is 14 inch better??? im clueless!!
Old Mar 16, 2003 | 12:12 AM
moremazda's Avatar
Gone Race'n
Re: i want an electric fan!!!info needed
Black Magic 150 Absoluty awsome!
Ryan
Old Mar 16, 2003 | 08:12 AM
im looking for cheap!!!
Old Mar 16, 2003 | 11:13 AM
vipernicus42's Avatar
Rotoholic Moderookie
you seem very excited!!! and your questions truly ponderous. why???
AT LEAST YOU AREN'T YELLING ALL THE TIME LIKE SOME PEOPLE!!!
Tha black magic is awesome, but I saw a thread a while back with some cheaper ones.... As for the swap, having not done my own yet, I can't really help ya. But I guess you can consider this a <BUMP> </BUMP> to the top so people who do know can help you, calm down your !!! and answer your burning ??? for you
Jon
Old Mar 16, 2003 | 11:42 AM
1st to 3rd's Avatar
If you want cheap!!!! Go to the junkyard and get yourself a fan from an early 90's Ford Taurus!!! All you have to do is drill two holes in the rad support to mount and it fits perfect!!!
Old Mar 16, 2003 | 12:18 PM
ok but can anyone tell me if its an easy swap???? im not really excited just eager to get mine in tip top shape thanks and sorry if i am bothering anyone with my questions!!!! but after all thats what the forum is here for! am i right??
Old Mar 16, 2003 | 01:07 PM
Vohaul's Avatar
the most popular of swaps for an electric fan is from the 80's pontiac fiero........apparently a direct bolt in
Old Mar 16, 2003 | 01:13 PM
inittab's Avatar
I read your email
Is it easy???? Can you use basic tools??? If you can then yes!!!! it's an easy swap!!!
Old Mar 16, 2003 | 01:18 PM
Viperx7's Avatar
I got mine(twin 10") from Summit. Think I paid about $60 apiece. Although not Black Magic, they pump 900+ cfm apiece. Keeps my Turbo cool enough. Very easy to install if you know basic wiring.
Old Mar 16, 2003 | 02:17 PM
ioTus's Avatar
'84 5-letter
The fan off of a ford temp works very well too, its very VERY quiet, lower profile, all black, and moves more air than the stock one!!! its so quiet you can run it constantly and its just fine!
it costs roughly $12 at a pull and save.
Old Mar 16, 2003 | 03:03 PM
PaulFitzwarryne's Avatar
Apprentice Guru
The question is it easy has still not been answered.
1. Removing the existing fan and cowl- relatively easy with stock tools you should have in your kit, repair manual such as Haynes not required.
2. Fitting the new fan- simple if you have picked the right secondhand part , just bolt in place or fit brackets.
3. Wiring the fan- extremely easy to wire just connect to any live feed- more difficult if you want to insert temperature control switch unless you have a little knowledge of wiring and some common sense.
Overall level of difficulty- simple modification
Time to undertake- two hours
Tools required- basic mechanics set
Cost - under $30 if good secondhand part available
Result- should be about 2-3 gain in hp
immanuel__7
89
Sep 5, 2015 10:23 AM
7aull
1st Gen General Discussion
Aug 14, 2015 10:44 PM
