Fuel cutout
Old Mar 15, 2003 | 07:46 PM
Fuel cutout
Last night i was on the interstate racin eclispe gsx and we hit about 110 then, all of a sudden my car just stop for like a second and then kept goin. then i was cruisin and the thing just shut off. this has happened before but usually when i turn the ac off. but when i start it back up it ALWAYZ starts on the second try never the first. anybody knoe y this could be happening.
Old Mar 15, 2003 | 09:46 PM
Turbo23's Avatar
Panda Bear
fuel cut shouldnt shut off your engine. It should feel like your engine pauses, then kicks back in. That used to happen to me in 4th at around 5k and in 5th at around 5k. It feels like it stumbles, but shouldnt turn anything off. Just get a FCD and see what happens,cant hurt and youll need one anyways
Old Mar 15, 2003 | 10:00 PM
NZConvertible's Avatar
I'm a boost creep...
Just so you know, fuel is cut to the rear rotor when you exceed 8.6psi boost because of intake and exhaust mods. A fuel cut defender (FCD) stops this by lying to the ECU about actual boost, but because of this they really only allow you to run 2-3psi more safely.
EDIT: We're presuming you actually have a turbo, but you don't mention this in either your post or your profile. Please give as much info as possible in your posts, and fill out the profile completely. It helps us help you. Thanks.
Old Mar 16, 2003 | 12:48 AM
HAILERS's Avatar
HAILERS
He has a 88 GXL. Does that help identify the type of RX-7?
Old Mar 16, 2003 | 06:36 AM
Then it's not a turbo, so it's not fuel cut. Could be anything...
Old Mar 16, 2003 | 11:44 AM
yeah no turbo. anybody else got suggestions
Old Mar 16, 2003 | 01:21 PM
hIGGI's Avatar
grounding/electrical wiring issues.....could be anywhere..
Old Mar 16, 2003 | 01:35 PM
HAILERS's Avatar
HAILERS
I'd get a analog volt/ohm meter and check out the tps for opens/shorts during its travel. Or get a digital meter and put the positive lead in the back of the TPS green/red wire, turn the key to ON, and run the tps thru its full travel slowly. Looking for opens or sudden changes in the output.
If during your 100 mph ordeal you over rev'd the engine, there is a cut at some high rpm, the figure I forget or never knew, but if rev'd to high it will cut out. That wouldn't explain the cruise cutout, though.
Its all a guessing game. Just got to eliminate the obvious first.
Most often the best thing you can do is duplicate the problem several times and put the pieces together from there.
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
