whats wrong with my se?
Old Mar 14, 2003 | 06:51 PM
hey whats up guys, please reply on this if you have any info, im having problems starting the engine, it has spark cause the tach works, or maybe that doesnt have anyhting to do with it, but it has gas, and oil, and new plugs, and wires, i just cranks over, and over and over im gonna go check spark, but any info would be awesome, the engine overheated and a friend told me the rotor housings mite be warped,.........any info on that also, lemme know, thanx,Jon
Old Mar 14, 2003 | 07:00 PM
vipernicus42's Avatar
Rotoholic Moderookie
Wow.... is it just me, or is this the third post of this nature in the last 2 days? "it won't start" general starting issues.
When you're checking for spark, check if the plugs are wet. What I'd do is check all 4 for spark, make sure that the wires are going to the right plugs, wipe the plugs off and take a brush to them if they look dirty. Then before putting the bottom ones back in, crank it by hand (turning the main pulley wheel away from you if you're standing on the driver's side) to get any excess gunk from the bottom of the chamber to bleed out the bottom holes.
you say it HAS gas and oil, but how recent are either? Bad/Black oil is a horrible thing and can lead to starting problems, since oil is a big part of the lubrication of the chamber, and consequently mixes with your gas
Oil change recommended, get back to us with details on spark and any further info.
Jon
Old Mar 14, 2003 | 07:01 PM
PS: If you have questions as such, do a search in the forum before creating a brand new thread, the issue has definitely been discussed recently.
And guys, as always if I say anything that seems.... wrong, don't be afraid to blatently point it out I am *still* just a newb with under a hundred posts and only a Heynes and lots of forum reading to help me along
Jon
Old Mar 14, 2003 | 07:51 PM
gump's Avatar
wow, join the club, i have the same problem right now. There is a good chance it is flooded, follow this procedure and hopefully it will help you out. http://www.nellump.net/peri/epi/firs...dEngStart.html
Old Mar 16, 2003 | 03:35 AM
sorry guys, i feel like such an idiot, i fixed the problem, some sort of regulator on it,,not sure if its stock,,it was froze shut, so NO fuel was going to the engine........well problem solved, maybe everyone else can check there se and see if that helod its right above the "13b" engraving on the housings, inbetwee the engraving on the drivers side and the manifold its on a line just below the throttle body,.........anyone familiar with it???!!!!? 197,000 miles and runs great,,.......the oil cooler is busted, but the oil pump doesnt start to bring the oil to the cooler until a certain temp.......other than that i have one in my parts car...thanx alot guys!!
Old Mar 16, 2003 | 03:39 AM
oh yeah and on my se.........where the choke **** would go on a "12a" carbed model theres a white plastic **** that goes in and out, but havent found anythting it does....anyone with any help?
Old Mar 16, 2003 | 11:38 AM
lotsacars's Avatar
My SE does not have this...I'm going to go ahead and assume that it's something somebody added to your car at some point. The only way to really identify what it does is to start tracing...
Old Mar 16, 2003 | 03:49 PM
Manntis's Avatar
add to cart
Mine does not have that **** either.
Old Mar 16, 2003 | 04:02 PM
Northern 7's Avatar
My SE has a pull out type **** similar to what you are describing - it controls my fog lights
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
