how to get "breakaway" blots off
Old Mar 14, 2003 | 01:49 PM
xxxbadassfoxxxx's Avatar
ok im taking out my ignition column cuz i need a new one and i took off the steering wheel and everything and im down to the retaining plate that holds the ignition cylinder on...there are 2 "breakaway" bolts on there...i have no idea how to get them off...anyone ever done this? they are flat things with a bump on top of it...no screwdriver fitting and no 6 sides or 12 sided bolt, it shouldn't even be called a blot but anyone have an idea please let me know...thanks...gerry
Old Mar 14, 2003 | 01:59 PM
HeffBoost's Avatar
Keep Right Except to Pass
Hammer & chisel. Or maybe you could do it w/vice grips.
Old Mar 14, 2003 | 02:00 PM
do you know what im talking about though? has anyone actually done this before??
Old Mar 14, 2003 | 02:04 PM
HeffBoost's Avatar
Yes, exactly. I've done it. You described it pretty well, the part that the key goes in, ignition switch.
edit - when you have 'em out, you can grind them down for a wrench, or just put a regular headed bolt back in next time.
Old Mar 14, 2003 | 02:06 PM
ok good, wonderful thanks a lot, so im just gonna smash them til they break then, hahah this should be fun eh eh eh eh
Old Mar 14, 2003 | 02:20 PM
uh yea i tried that, it broke my ******* chisel...what now...the vice grip won't fit around it there isn't enough room
Old Mar 14, 2003 | 02:21 PM
Crionics's Avatar
but not too much fun I hope
[EDIT]
You had to go and break something before I warned you now, didn't you...
[/EDIT]
Old Mar 14, 2003 | 02:24 PM
HeffBoost's Avatar
Broke your chisel? I guess I wasn't all that clear. I meant to turn them with the chisel. "smash them 'til they break"? No smashing. Just get a good bite where you'll have some meat to dig into in the direction you want to go.
Old Mar 14, 2003 | 02:59 PM
hahahahahaha, ohhhhhhhh, well i totally misunderstood now didn't i, well i will try that also..thanks
Old Mar 14, 2003 | 07:46 PM
Silkworm's Avatar
Has been.. hangin' around
Dremel a slot in the top of the bolts. Screwdriver backs them right out.
purerx7
Jul 16, 2015 09:41 AM
RX7Zamboni
Jul 3, 2012 12:10 PM
