Power FC map sensor and boost gauge disagree
Old Mar 10, 2003 | 12:53 PM
93BlackFD's Avatar
built my own engine
my map sensor reads .80kg/cm2 when my boost gauge reads 10psi
how can I correct this?
which is more probable to be correct?
Old Mar 10, 2003 | 01:44 PM
jeff48's Avatar
Rotorally Challenged
This is one of those notorious Power FC issues but to be sure you should test the gauge and commander outputs separately using a mityvac or equivalent. At .8kg/cm2 you should be showing 11.38 psi.
Old Mar 10, 2003 | 07:32 PM
Tim Benton's Avatar
FD title holder since 94
go with the PFC.
Tim
Old Mar 10, 2003 | 09:53 PM
skotx's Avatar
Registered Abuser
It's odd that your Power FC is showing higher boost than your gauge. It's the other way around for most of us.
Old Mar 11, 2003 | 06:46 PM
cewrx7r1's Avatar
Eye In The Sky
Do not go with the PFC boost reading or your gauge.
Both are wrong.
The PFC has been proven wrong by many knowledgeable people. I have posted documented proof about this on this forum. Do a search.
Snoopy FD
Dec 8, 2015 01:45 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
