Greddy T78 turbine Housings?? different A/R's?? RX-7/Supra
Old Mar 8, 2003 | 05:27 PM
pistonsuk's Avatar
i bought a used t78 from a guy that had it on a supra. i have heard that there are two turbine housings offered, one for the rx7 and one for the supra. i assume the rx7's is a higher A/R than the supra's.
i was wondering if this is true, and if so what are the respective A/R's?
thanks
justin
Old Mar 8, 2003 | 07:17 PM
setzep's Avatar
If you could, post a picture of the turbine housing then someone could tell you what it is. Mitsu turbos are measured in cm not a/r. I think the three available housings are 14cm, 17cm and 24cm. I was told that I have the 17cm housing on my turbo but after looking at voskos I think mine is the 14cm, his is larger than mine.
Ian_D
Oct 14, 2015 12:31 PM
AXA
Sep 5, 2015 10:06 AM
apooch
Sep 4, 2015 10:27 AM
