big problem with wheel!!!!!!
Old Mar 4, 2003 | 08:42 PM
xlversatilelx's Avatar
**** it was raining so i rive my car and i crash into the curb yeah i knoe stupid, but i really need your help. the tire was totally ripped off, and the place where you attach your tire to the car is totally stripped so i cannot put the tire back on. i was wondering if this piece is easy yo take off and can be found at a junk yard? so yeah please help me i am in desperate need !!
Old Mar 4, 2003 | 08:48 PM
gamble302's Avatar
roadkill hats rock
whoa be more specific. tire is just the rubber. if you mean the wheel wont bolt back on you gotta tell us
Old Mar 4, 2003 | 09:23 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
How hard did you hit the curb for your wheel to come off the hub? (Assuming I read your post right and it was the wheel and not the rubber.)
Old Mar 4, 2003 | 09:30 PM
coldy13's Avatar
Yeah, shutup kid.
Sounds to me like he is saying he completely ripped the whole damn wheel off. Stripped out the brake rotor, so the lug nuts won't thread into it anymore.
If that's the case, you will need a new brake rotor and a serious alignment job/replace the suspension parts you bent.
Yes, you could probably get it pretty easy at a junkyard, you just have to know exactly what you need. Take some pics too, I wanna see how bad it is
Old Mar 5, 2003 | 12:39 AM
i dont think its taht bad all i think i have to replace that has major damage to it is where you bolt on your wheel to the car so i guess the hub, the threading is stripped to no wat i can attach it back on so anyon knoe if i can get thei done for cheap or any other ideas please help
Old Mar 5, 2003 | 08:17 AM
Rotor13B's Avatar
Wassup!!
Uh, I think he means just the studs are stripped. If that's the case, just buy some new wheel studs and go get an alignment. On a side note, have you been drinking? lol
Old Mar 5, 2003 | 02:23 PM
hhaah no i have not been drinking but yeah thanks a lot that really helps i appreciate it, and would i just be able to get the studs and bam i replace and get my alignment done and bam im ready to go again ?? please help meeh !
Old Mar 5, 2003 | 02:51 PM
RotorMotorDriver's Avatar
Seven Is Coming
**** son, Im confused .
I think that when he hit the curb, it ripped the wheel off, stripping the holes on the brake rotor. That makes sense to me... I would just think that there would be more damage than just that.
~T.J.
Old Mar 5, 2003 | 03:54 PM
12aPwr's Avatar
did your spindle break? thats what happened to mine when i got it, it shouldnt be that difficult to replace
p.s. if your spindle broke you have to replace the strut housing or whatever its called
Old Mar 5, 2003 | 04:40 PM
on where you place the wheel on to the car, the hols are stripped, and there is no way to place the tire back on with out it falling off, so i was wondering what do i need to get replaced?
Old Mar 5, 2003 | 05:12 PM
lotsacars's Avatar
You might want to have someone you know who's very competent mechanically take a look at it. It's very hard to diagnose your problem without actually seeing what you're talking about. I don't want to see our forum advise sell you one part short and have your wheel come flying off again.
Old Mar 5, 2003 | 07:44 PM
Rotor13B's Avatar
Wassup!!
I would upload a pic if I were you. Go get one of those cheap cameras with like 12 exposures and take some pictures of the damage. When you get them developed, make sure you check the cd box on the film package, that way you can upload to the forum without having to scan them.
Old Mar 5, 2003 | 09:58 PM
well here basically the wheel hub where you attach your where, where you bolt it on, they are stripped, and i just want to knoe how can that be replaced what do i need
Old Mar 5, 2003 | 11:49 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
If that's the front wheel hub that got creamed, you will need a front rotor and hub and possibly/probablly new front wheel bearings, races, packed with grease and new lug nuts or now's a good time to switch to lug studs and normal lug nuts which can be gotten at good price from:
www.sevensonly.com.
If it's the rear that got creamed you're looking at new or more likely used junkyard rear axel and studs/nuts plus bearing. Possibly calipers and mounting brackets.
I work in Cerritos and live in Redondo Beach, CA. Owned a 81 7 since 1988 If you'd like me to check out your car just PM me.
Later,
-bp-
-bp-
Old Mar 6, 2003 | 03:09 AM
poweRX-7's Avatar
no, but seriously? have you been drinking? hahaha
Old Mar 6, 2003 | 04:19 PM
sweetege's Avatar
bzzzzzzzzzzzzz
i'm glad that did'nt happen to me. a while back me and my brother were riding in the rain and spun the car around while switching into second and hit the front right tire on the side, did'nt hurt the wheel but every bump or vibration in the road that we felt after that, we blamed it on the tire. cool experience.
we were'nt drinking......that i remember. j/k
Old Mar 6, 2003 | 06:41 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
I slightly damaged two of my rear axle threads last year when I failed to tighten an axle puller on well enough (was doing my rear wheel bearings). I was able to use a tap to clean/redo the threads to save replacing the axle - good as new. What you're talking about sounds a lot worse than what I did though (I could bolt on wheels but the lug bolts would get stripped when I unscrewed them).
Old Mar 7, 2003 | 09:02 AM
jeremy's Avatar
male stripper
holy ****. the title of this thread should be something like.........
i was trying to wrc in the rain and ripped off a wheel
and then give out an english translator and/or some excedrin.
good luck man. also check the whole suspension as you probably bent other things. check the frame for any bends or fractures and get an alignment when fixed.
Old Mar 7, 2003 | 09:40 AM
MosesX605's Avatar
Chances are if you hit the curb with enough force to break off your wheel, there's other damage to your car besides some wheel studs. Definately get the car checked out by a professional if you can't yourself.
Old Mar 7, 2003 | 10:46 AM
gamble302's Avatar
roadkill hats rock
curbs are nothing. i let a guy drive my car, he smacked a curb goin like 40 and all i had to replace was the control arm. cost me less than 100 bucks even after the alignment
pics here:
http://community.webshots.com/album/38755932xMAnAd
Old Mar 7, 2003 | 09:41 PM
Siraniko's Avatar
RX for fun
Re: big problem with wheel!!!!!!
dude
Drive up to any junkyard and just grab the entire strut assembly along with the hub and rotors. I live in Los Angeles and last week, there were at least 4 1st gens at pick up part in sun valley. Its not hard to do just bring a coupe of tools. 14mm to unbolt the strut tower and 17 mm to unbolt the bottom and a knife to cut the brake line off.
there ya go. If you need help, let me know.
late
Pinoy
Queppa
Nov 18, 2024 03:47 AM
diabolical1
30
Jan 30, 2016 05:50 AM
Snoopy FD
Dec 8, 2015 01:45 PM
