Vacuum Check Valve Question
Old Mar 1, 2003 | 01:01 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
I'm speaking of the round one-way check valves near the top vacuum chamber, but I guess all check valves in general. To check to see if they are working properly you should be able to blow in one end but not the other, but how fast should the air flow out of it? Should the valve make a whistling sound? Thanks in advance.
Old Mar 2, 2003 | 06:29 AM
HDP's Avatar
HDP
Anyone?
Old Mar 2, 2003 | 08:57 AM
Mahjik's Avatar
Mr. Links
Re: Vacuum Check Valve Question
You should only be able to blow through it "one" direction. However, you should be able to "suck" through it the other direction.
If you can blow through it both directions, replace it.
Old Mar 2, 2003 | 09:19 AM
Tim Benton's Avatar
FD title holder since 94
Don,
When are you going to make it over this way again?
A good site with great turbo info is Derek's site...
http://www.autosportracetech.com/RX-7/rx7stuff.htm
Tim
Old Mar 2, 2003 | 11:41 PM
duboisr's Avatar
some have a filter thing and are hard to blow through with your mouth.
Old Mar 3, 2003 | 04:10 AM
HDP's Avatar
HDP
Re: Re: Vacuum Check Valve Question
Thanks for telling me EXACTLY what I already know
Old Mar 3, 2003 | 04:17 AM
HDP's Avatar
HDP
Originally posted by Tim Benton
Don,
Tim
I'm shooting for the weekend of March 22. I hope by then, to have the 7 back together and running "properly". Right now I'm in the process of doing the vacuum hoses and replacing the downpipe. I plan to send it off this week to have it coated, so I hope to in stall it next weekend. I just hope there's good weather for the next couple of weekends.
Old Mar 3, 2003 | 12:31 PM
apneablue's Avatar
as for how fast air traveles through the check valve, I couldn't give you an exact value. BUT what you could do is grab another one like it (there are two kinds: Green/Black & Green/White) and blow through both of them and see if they flow the same...If they do then I believe you are golden.
I would have to say the flow is about : weeeeeeeeiiiishhhhh! NOT Wooooooosh!, Woooooosh is about the sound of a torn/broken y-pipe coupler
Old Mar 10, 2003 | 05:11 PM
HDP's Avatar
HDP
I found an aluminum check valve. It flows air both directions. Is this correct? I didn't see a check valve like this on the parts list. Can anyone help me on this?
Old Mar 10, 2003 | 05:55 PM
HDP's Avatar
HDP
I found a pic of the aluminum check valve, but this #@%* message board won't let me upload it.
Old Mar 10, 2003 | 06:11 PM
Mahjik's Avatar
Mr. Links
If you can blow through it in both directions, it's not functioning correctly (hence the name, check valve).
Check this thread and see if it's the same part:
https://www.rx7club.com/forum/showth...threadid=88176
BTW, I believe attactments are disabled currently.
Old Mar 10, 2003 | 06:13 PM
Benjamin's Avatar
Hiram--I've got both of the stock CRV's, if you need them. $12 each, shipped. I'm leaving for a business trip on thursday, so let me know before then.
-BN
Old Mar 12, 2003 | 08:48 AM
HDP's Avatar
HDP
Is there a thread that has details and the color of each check valve? There's no detail of this on the vacuum hose diagram.
Old Mar 12, 2003 | 08:53 AM
xstacy7's Avatar
I love when things work
hey guys...mine does the same. Just curious, can you replace the aluminum check valve with one of the other one's to eliminate that small hose>big hose>small hose. I can explain more if you like. I was down at pettit racing and cameron gave me some off a corvette. they are the same size and work GREAT!!! plus they're like 3 times cheaper
Old Mar 12, 2003 | 12:21 PM
HDP's Avatar
HDP
Please do. Anything to save a little $$
dkwasherexd
May 27, 2017 04:51 AM
turbo-minivan
69
Feb 4, 2016 12:29 AM
elfking
Aug 19, 2015 09:48 PM
