Injectors cheap
Old Feb 27, 2003 | 12:12 PM
LTProject's Avatar
Red face Injectors cheap
Just got some 1680 injectors from a guy in texas. I paid 300 for 4 of them. They had a ford part# on them so i called ford, since i work at another dealership my cost is 55.00 and retail is 78.00. They fit a Crown Victoria natural gas model yr 2000. Part # is xl3e-c5a.
Old Feb 27, 2003 | 12:21 PM
dcee's Avatar
I bought the Ford Motorsports ones which are for a Natural gas car as well. Part Number : f5te-b5a (280 150-839). They are 1650cc.
~50 bucks each with discount
Old Feb 27, 2003 | 02:59 PM
neoamd's Avatar
LS Powered
will they work for 3rd gens?
Old Feb 27, 2003 | 03:02 PM
dcee's Avatar
They are top fed , I aint sure what the 3rd gen Rx7's are and they have a different style wiring connector. Of course you could just change the injector connector but not sure about physical fitment.
Old Feb 27, 2003 | 05:06 PM
Cheers!'s Avatar
Former Rx7 *****
wohooo! score one for FCs
Old Feb 27, 2003 | 09:02 PM
LTProject's Avatar
Im sure some guys already know of these, but for the ones who pay to much ie(myself) this threads for you. For those RX owners out there screwing fellow 7 lovers, eat **** you sob's!
Old Feb 28, 2003 | 04:49 AM
heu heu sounds good, looks like i have a good lead on where my next injectors will come from
Old Feb 28, 2003 | 06:31 AM
rxrotary2_7's Avatar
WOW i will have to look into those. i was never able to get a straight answer from anyone on what the part number would be. i have paid to much myself now that i see this, and i always thought i was on the lower side of the price. i have a set of rails for 160lb secondaries if interested. https://www.rx7club.com/forum/showth...hreadid=162060
Old Feb 28, 2003 | 07:45 AM
LTProject's Avatar
You can buy bulk fuel rail with 1/2 id from ForceFuelInjection. Its about 5 to 10.00 a foot, they also sell the weld on injector seats.
Old Feb 28, 2003 | 01:46 PM
dcee's Avatar
$215 for injector rail!?!
Old Feb 28, 2003 | 02:23 PM
yeah, shipped. its $215 for a primary AND secondary rail. that $5 cheaper than k2rd's rail that they sell only a secondary, but you are also getting a primary rail. i am including a primary top feed rail for very slightly less than k2rd's that wont work with a top feed primary rail. show me where you can get BOTH for that price without making it yourself. even if you did take the time to plan it out and actualy make it yourself, do you have the right tools/machines to do so? a hand held drill is not going to "cut" it... no pun intended.
if you dont want it, dont buy it, its that simple.
Old Feb 28, 2003 | 02:38 PM
dcee's Avatar
Hey, If that is the going rate. I am not trying to knock it . I was just surprised.
Old Feb 28, 2003 | 07:44 PM
skunks's Avatar
I'm a CF and poop smith
so are these injectors for FD's? I'm assuming these are for FC's.
Old Feb 28, 2003 | 10:00 PM
LTProject's Avatar
Im pretty sure they wouldnt fit a FD b/c they are topfed, but maybe if you upgraded the rail at the same time you could switch to them. food for thought
Old Mar 1, 2003 | 11:29 AM
black99's Avatar
Lurking..................
A stock FD uses side feed injectors but if you're going to be using 1600cc injectors most people upgrade at least the secondary rail to get them to fit and I think most of the upgraded secondary rails for FD's out there are top feed rails.
Old Mar 1, 2003 | 02:08 PM
black99's Avatar
Natural gas model crown vic? Same thing as just a plain crown vic correct??
BTW, are you guys getting these from your local ford dealer?
Old Mar 2, 2003 | 08:46 AM
LTProject's Avatar
Yes your local ford dealer either stocks them or can order them.
Old Mar 2, 2003 | 10:40 AM
dcee's Avatar
Local Ford dealer will probably have to order them but I don't think they are the same as a 'plain' gasoline powered Crown Vic.
Old Mar 2, 2003 | 09:14 PM
SaabGuy's Avatar
How the hell do you fill the tank on a natural gas vehicle?
Old Mar 3, 2003 | 08:17 PM
Cheers!'s Avatar
Former Rx7 *****
you need to convert your car to natual gas... most taxi cabs use propane or nat gas
but a fluid is just fluid regardless so theinjectors should be ok
Old Mar 3, 2003 | 11:20 PM
Ni5mo180SX's Avatar
White Comet
Now, if only I could find cheap 680cc-850cc injectors for the FC
Old Apr 29, 2003 | 05:27 PM
setzep's Avatar
Are these ford injectors high imp?
Old May 1, 2003 | 08:53 PM
dcee's Avatar
I don't know their impedance but I do know that they are greater 1.2 Ohms(each). Otherwise they wouldn't work with my WOLF3D ECU.
Hope that helps.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
