Will s5 turbo fix boost creep?
Old Feb 26, 2003 | 06:58 PM
If I install a s5 turbo on my s4 T2, will the wastegate still have to be ported?
Old Feb 26, 2003 | 07:29 PM
porting the wastegate is not a bad idea but not really necessary unless you are doing major high speed driving or running higher boost levels...
Old Feb 27, 2003 | 02:44 AM
S2-13BT's Avatar
Are you having a boost creep problem. The S5 turbo does have a bigger wastegate opening (2) so it can help, but whether it will solve your problem, will depend on how much flow you need.
You could consider an external gate.
Old Feb 27, 2003 | 04:16 AM
HeffBoost's Avatar
Keep Right Except to Pass
Port it while it's out. I've never heard anyone complaining about "too much wastgate flow".
Old Feb 27, 2003 | 06:18 AM
HeffBoost's Avatar
These guys have the answer to boost creep on the S5 turbo. Check out the link at the bottom to dcee's post. Good before and after shots of the wastegate.
https://www.rx7club.com/forum/showth...hreadid=160754
Old Feb 27, 2003 | 07:49 AM
dcee's Avatar
Well what mods have you done to the car so far. Heffboost is right though, you can't have too much wastegate flow. So if you have the W/G out you might as well port it. You never know what upgrades you will do in the future.
Old Feb 27, 2003 | 07:51 AM
dcee's Avatar
My ported & modified wastegate project post is at https://www.rx7club.com/forum/showth...hreadid=155100
Old Feb 27, 2003 | 11:40 AM
I have a full RB exhaust setup. 2.5 dp and midpipe, and then the cat back system. I have a apexi cone filter on the front of it and a RB FCD. I just want to run safe boost levels and I can get a s5 turbo cheap from someone i know.
Old Mar 4, 2003 | 06:25 PM
GlenL's Avatar
dcee: Your pics on the thread don't show up anymore for me. Did the link change or is it just me?
Old Mar 5, 2003 | 06:46 AM
dcee's Avatar
they seem to be working. if they don't work, go to:
http://www.dcee.rotarymaniacs.com/tu...turbopics.html
This has all the pics on it and more.
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
tsmith94FD
Aug 16, 2015 05:41 PM
