T-88 owners, please reply!
Old Aug 18, 2001 | 01:54 AM
nyt's Avatar
nyt
im not a t88 owner but im pretty sure thats teh baseline for the spring in the type c wastegate
Old Aug 18, 2001 | 09:37 PM
crispeed's Avatar
'Tuna'
I'm not a T-88 owner either but I sure wish I were !!!!
crispeed
87TII
9.20@150mph
Old Aug 19, 2001 | 12:18 AM
RX794's Avatar
NYC's Loudest FD
My Greddy T88 kit came with a 20 psi spring, the spring dictates the minimum boost level once you turn the adjustment screw for the wastegate all the way. Most of the Greddy T88 kits are sent with 16psi springs, therefore it's the lowest boost you can run. I used 20 in everyday driving with no problems as long as you have the proper fuel supply and management.
Old Aug 19, 2001 | 01:02 AM
lesd's Avatar
You can always cut-shorten the spring to get a lower base boost. In case you have bad fuel, etc.
-Les
Old Aug 24, 2001 | 10:38 AM
flying taco's Avatar
Rock Star.... almost
Ok..... here's what u do... drill a hole near the end of your muffler... in that hole, secure a spark plug. Next, connect the spark plug to your battery terminals with a switch intermidately along that wire, then placed somewhere inside your car. When you start to smell that Sonoco smell... just flip on the switch and see if u smell it anymore!! Instead of the gas smell.... u might detect the lovely scent of burning plastic from the car behind you
FT
Old Aug 24, 2001 | 01:23 PM
Jedon's Avatar
Slave2TheFD
I'm pretty sure you would need a coil to feed the spark plug, I doubt 12volts is gunna do it.
Old Aug 24, 2001 | 04:27 PM
Want2race's Avatar
Bigger and better things
Whats your timing set @ ? SOunds a little retarded.. That could be why..
Old Aug 24, 2001 | 07:45 PM
Red-Rx7's Avatar
Administrative Me
Originally posted by CPunla
I have a 93 FD
- stock engine
- T88 kit
- Apexi Power FC
- 850 primaries
- 1600 secondaries
- RP Comp fuel pump
- Jacobs Rotary ignition kit
- and a whole mess of little extras
I'm running 16.5psi. My car starts popping around 5400rpm, my back bumper on top of my exhaust is black, and it smells like Sunoco on idle and when I drive. (too rich)
SOMEONE, HELP TUNE!!!!!!!!
Well, no one can help unless you provide more information.
1) Whats your base fuel pressure
2) Under WOT / Idle / Cruising, whats your Timing? Whats your trailing timing set to?
3) Under WOT / Idle / Cruising, what mS of injector time are your injectors pushing?
4) When do you have your secondaries coming online?
5) What kind of spark plugs are you running?
6) Stock coils / ignition setup?
7) What kind of plug wires are you using?
Your poping is directly indicating that you have ignition break up. You need to:
- Correct any fuel problems.
- Correct any timing problems.
- Correct any spark plug issues.
- Add an ignition amplifier to your system.
To correct the 3 first issues, we need to know more information.
Mike
Old Aug 26, 2001 | 09:41 PM
ZoomZoom's Avatar
SEMI-PRO
When you set it up with big secondaries it will run like hell except under WOT and high RPMS. Go check out the Injector sizing and boost/fuel charts on rx7.coms web site
RX7-RR
Jun 10, 2018 11:40 AM
Bauer778
Nov 4, 2015 04:42 PM
