Sponsored by: CARiD
Difference 12A to 13B?
Old Feb 21, 2003 | 01:39 AM
wdwflash's Avatar
I've got two cars with 13Bs in them, so I haven't really looked at the 12A. A friend asked me if the bell housings were the same and I didn't know. I know that manifolds don't interchange without adapters,but what about bolt patterns on the bell houseing and being able to bolt a 13b to a 12a trans. Are the flywheels/clutch different? He wants to bolt a rotary into his kit car, he bought an adapter off of ebay and wants to know if it will fit the 12A and 13B. Also, what about the '93-95 rotary engine is it just a 13B or is there a difference? What is interchangable between the 12A &13B, if anything.
Old Feb 21, 2003 | 02:40 PM
jeremy's Avatar
male stripper
all 1st gens trannies bolt to the block. i'm not sure if all 2nd gens do but i know the na's are the same. turbos might be different.
Old Feb 25, 2003 | 05:59 AM
genrex's Avatar
Here's two websites your friend should know about:
http://shoptalkforums.com/bbs/cgi-bi...ne=&LastLogin=
The first one is about engine conversions (lots of rotaries there!), and the second one is about kit cars. Lots of good reading material.
Old Feb 26, 2003 | 09:14 AM
peejay's Avatar
Old [Sch|F]ool
All '74-02 rotaries have the same bellhousing pattern. I do not know about the new side port engine at this time.
A '74-78 13B and '74-up 12A are practically identical. The 13B just has 10mm wider rotors, and everything related to engine length is stretched accordingly. Side housings and front covers interchange directly, as do all the internal engine seals not related to rotor width.
The GSL-SE engine is essentially a '74-78 13B with 6-port end housings and injector bungs in the center housing. You could mix and match to make a 6-port 12A (if you can find an intake manifold for it... 6-port carb 12A's were sold in the home market) or you could make a 4 port 13B, and the GSL-SE center housing can be used in any of them to make fuel injection more painless.
The '86-up engines have different intake manifold bolt patterns, thinner 3-piece apex seals, and the water seals were relocated to the side housings. There were other minor changes but the basic blocks can be swapped provided you are aware of the intake bolt pattern issue. A 85-earlier front cover can be swapped straight on to allow the engine to be fitted easily to a '85-earlier chassis.
Old Feb 26, 2003 | 03:54 PM
jeremy's Avatar
male stripper
good to have you back peejay.
jsesq
27
Sep 25, 2015 11:10 AM
AXA
Sep 5, 2015 10:06 AM
tonka_1956
Sep 2, 2015 05:55 PM
