is this normal??
Old Feb 20, 2003 | 10:29 PM
snakes99's Avatar
is this normal??
ok, when i get going like 110- 120 my car seems to start to get very hot, i never let it get too hot, i shut it down before then, but if were to keep it giong, i think for sure it would over heat, i was wondering if this happens to others too or if its a problem with my car. i would just think going 120 things would be able to stay on the cooler side, but i could be wrong.
Old Feb 20, 2003 | 11:08 PM
Directfreak's Avatar
I am a Jeeper Now.
Your waterpump is cavitating.
Old Feb 21, 2003 | 12:14 AM
Redwood's Avatar
Find Racing
Yup. The only real choice is to get an electric water pump. Very cool. Not cheap.
Or I guess you could run thicker water ... hmmm ...
Old Feb 21, 2003 | 02:08 AM
RotorMotorDriver's Avatar
Seven Is Coming
Or run a dual belt pully...Doesnt that help?
~T.J.
Old Feb 21, 2003 | 02:19 AM
RacerX7fb's Avatar
paradox
Changing to a larger main drive pulley will lower the water pump as well as alternator RPM, reducing coolant cavitation. Dual belts keep it from slipping once the air pump is removed.
Old Feb 21, 2003 | 03:15 AM
xxxHondaGuyxxx's Avatar
I dont think I've even gotten my car to 100mph yet. I'm scared it will wobble to pieces.
After 80mph, the car will start with the vibrating. What would that be......unbalanced tires?
Old Feb 21, 2003 | 06:49 AM
85RX7GS's Avatar
It could be your tires, but it could also be any number of other things. Start with checking the tires because that should be the cheapest.
Old Feb 21, 2003 | 07:41 AM
jeremy's Avatar
male stripper
you could also use water wetter. that help some. otherwise its an underdrive pulley for you.
Old Feb 21, 2003 | 07:46 AM
V8kilr's Avatar
ditto
Old Feb 21, 2003 | 07:52 AM
Mireck 12A's Avatar
Racingbeat dealer
Nope it is not normal,
replace you waterpump ...
original pump should do the job...
or maybe the cooling system is cloched...
Old Feb 21, 2003 | 08:36 AM
Mark S's Avatar
I agree with Mireck. The pump shouldn't cavitate till 7K. Chances are you either have a loose of slipping belt, or a bad pump.
Could also be a bad pressure cap, partially clogged rad, bad thermostat, etc
I would start with by tightening/replacing your belt first. It's always best to start cheap
Old Feb 21, 2003 | 08:39 AM
I am a Jeeper Now.
Actually, - Make sure you even have a thermostat, Rotaries need thermostats or the water will run loops around the thermostat hole and bypass, and will never really see the radiator.
Old Feb 21, 2003 | 10:26 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
This is backwards. A larger main pulley would make the water pump spin faster.
Old Feb 21, 2003 | 10:48 AM
pratch's Avatar
Mazspeed.com
Sterling beat me to it!
Smaller pulley = smaller distance moved each revolution. Larger pulley = larger distance moved each revolution and :. higher rpm on pump.
Einheri
Oct 7, 2015 12:23 PM
binz
Oct 2, 2015 03:52 PM
93FD510
Oct 1, 2015 02:00 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
