Question - The best Sway bars? Best Price?
Old Feb 17, 2003 | 11:20 PM
Fire85GSLSE's Avatar
Chad Carson
I have been buying the parts to hit the SE all at once.
I am down to swaybars and can not figure out what I should run. What brand is the best for the buck?
Also what should I put in the tranny and rear end?
I plan on changing that also.
Here is what I have sitting in the garage waiting until next month,
Eibach springs, Tokico shocks/struts, Racing Beat Streetport exhaust system, Tri Strut bar, MSD 6a, under coating, Ball joint , tie rods, and once I decide on the sway bars I am gonna order new bushings for the whole car.
Old Feb 18, 2003 | 11:23 PM
Chad Carson
I guess everyone that has a 1st gen has stock sway bars?
Bump^
Old Feb 19, 2003 | 12:12 AM
TheTwinTurboRX-7's Avatar
I have an option to buy some for a hundred and a half, no idea what kind, probably not going to though.
Old Feb 19, 2003 | 01:23 AM
Rotary13B1's Avatar
As far as the front ones go...I'll be getting a RB unit ...
From their website:
1979-85 RX-7 Front Sway Bar (shown left above)
Our Racing Beat-designed sway bars reduce chassis roll in turns and increase the RX-7's sensitivity to steering input, thereby improving maximum cornering power. We engineer these components to provide optimal front-to-rear balance utilizing select steel alloys, controlled heat-treating, and specific bar diameter and geometry.
This 1.125 inch OD sway bar completes with mounting hardware (including high-density urethane mounting bushings and bushing lubricant) and installation instructions. All Racing Beat sway bars utilize the stock sway bar links.
Sway Bar - Front
1979-85 RX-7
Part Number: 14100
Retail Price: $121.00
Old Feb 19, 2003 | 01:28 AM
spoolin's Avatar
you will be pleased. i had it and the racing beat strut tower brace and springs......and a bolt in auto power cage. it sure was firm in the corners. i mean with authority...it handled
Old Feb 19, 2003 | 01:32 AM
Hyper4mance2k's Avatar
The Shadetree Project
will a bigget sway bar in the front promote more understeer??
Old Feb 19, 2003 | 02:14 AM
RotorMotorDriver's Avatar
Seven Is Coming
Any pics of the bolt in cage?
~T.J.
Old Feb 19, 2003 | 02:17 AM
Seven Is Coming
Damn double post...
~T.J.
Old Feb 19, 2003 | 07:57 AM
RacerX7fb's Avatar
paradox
Yes Racing Beat front bar.. I still use the stock one in the rear. Another option would be Suspension Techniques or TMC.
A good synthetic MTL in the tranny but NOT in the rear diff! Use regular dino gear lube back there with a LSD additive.
Old Feb 19, 2003 | 11:58 AM
Manntis's Avatar
add to cart
I'm running the RB front swaybar as well. Nice difference in cornering - if you ignore the inherently sloppy steering, the cornering itself is quite firm.
Old Feb 19, 2003 | 09:21 PM
JDuncan's Avatar
Anyone had any experience with the Eibach kit?
matty
Jan 18, 2020 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
need RX7
11
Aug 19, 2015 08:27 AM
