Acceptable compression ranges
Old Feb 17, 2003 | 10:29 PM
JBurer's Avatar
Can someone tell me what psi ranges indicate acceptable compression on a 13B-rew when the engine is COLD?
The Hayes manual for the second gen says 85 is the minimum, but that is with a fully warmed up engine....
Any help is appreciated!
Best,
John
Old Feb 18, 2003 | 02:18 AM
Nathan Kwok's Avatar
One test I know of where cold/hot tests were done almost back to back (within a week) showed the cold test resulted in numbers almost exactly 1.0kg/cm^2 or 15psi higher than the hot test. So, using that as a basis, if the manual says 85psi is the minimum hot, then 100psi is the minimum cold.
rp
Old Feb 18, 2003 | 10:25 AM
JBurer's Avatar
That's interesting. I always thought it would be the other way around... hmmmm.
Best,
John
Old Feb 18, 2003 | 10:37 AM
Wargasm's Avatar
Weird Cat Man
The numbers are usually higher when the engine is warm.
Old Feb 18, 2003 | 10:56 AM
Where did you hear this? Mazdatrix told me the opposite (which seems to concur with that one case), but thats all I have. The only other piece of imperical evidence I have is that when compression starts to get critically low, cars tend to develop "hot start" problems before cold start problems (see factory manual in the troubleshooting section). I'm also not sure if this applies only to low compression turbo motors or to n/a motors as well. Ideas anyone?
Old Feb 18, 2003 | 11:14 AM
Marshall's Avatar
I always heard better when warm too because everything expands and seals up. Interesting.
Old Feb 18, 2003 | 11:19 AM
Wargasm's Avatar
Weird Cat Man
Those are some of my observations using my rotary engine compression tester...
Brian
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
