windshield washer pump not working? Help
Old Feb 17, 2003 | 06:45 PM
bparke3's Avatar
My winshield washer pump is not working, any suggestions, i took out the tank and cleaned it no hles or anything. Not sure what else to check any guidlines??
Old Feb 17, 2003 | 06:48 PM
RotorMotorDriver's Avatar
Seven Is Coming
Check fuses and stuff. Make sure its plugged in and has a good connection.
~T.J.
Old Feb 17, 2003 | 10:24 PM
brownmound's Avatar
Anytime baby!
remove the motor from the reservoir and see if it's seized or test it with 12 volts. if it's broken you can get a replacement with ease at an Auto parts store.
Right on.
Old Feb 17, 2003 | 11:32 PM
Rotary13B1's Avatar
Yup...brownmound is right on.. or you can get one *free* at your local junkyard while you are *shopping*..and pray it works like I did...
Old Feb 18, 2003 | 12:14 AM
ioTus's Avatar
'84 5-letter
My solution: take out the reservoir and clean otu the engine bay. Reduces wieght (by ounces!!!) and cleans up the look a lot.
Old Feb 18, 2003 | 02:53 AM
rgus30's Avatar
check fuses, fusable link maybe,bad motor, what ever
it all else go to J yard pull it ofrf another rx7
get it there it cheep or even free
Old Feb 18, 2003 | 11:08 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I'm using an RX4 washer tank and pump, presently. Fits perfectly.
Old Feb 18, 2003 | 11:22 AM
sweetege's Avatar
bzzzzzzzzzzzzz
I was thinking about taking my washer motor and mounting the sprayers right in front of the radiator for auto-x season and spray water on it too cool it down. Since it does'nt work with power in the engine bay I might run it seperately from the battery or put another battery in it to run it.
Old Feb 18, 2003 | 12:06 PM
Wankelguy's Avatar
Interesting idea, but it may not be legal, depending on the class you run in.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
astrum
24
Nov 15, 2017 08:44 AM
FD7KiD
Aug 17, 2015 11:50 PM
