Smoking
Old Aug 16, 2001 | 03:31 PM
UniqueTII's Avatar
Slow and old
Smoking
My Turbo II smokes a lot ofter a full throttle run up to redline. If I hold it at redline for a second or 2 and then shift I create an instant smokescreen. Should I suspect my engine seals? It started doing this last summer and I thought it was my turbo seals, so I had the turbo rebuilt/upgraded, and it hadn't been doing it lately, but started again today the other day. Is there any way to check the engine seals without taking it out and apart?
Old Aug 16, 2001 | 03:48 PM
cymfc3s's Avatar
I Raise Chickens
oil control rings are going out. Just keep driving it until you can afford to rebuild the motor.
Old Aug 16, 2001 | 06:10 PM
UniqueTII's Avatar
Slow and old
Thanks Seth. Am I correct in assuming that it's going to smoke worse as I put more miles on the car?
Old Aug 16, 2001 | 06:35 PM
CNYRX7tech's Avatar
Lightbulb
Ed,
I have also had this problem and it will only get worse. cheap trick is to remove oil filler cap which reduces crankcase pressures.
Old Aug 16, 2001 | 07:17 PM
cymfc3s's Avatar
I Raise Chickens
i wouldnt drive around with cap off, creates a vacuum leak and makes a mess if the engine bay.
ls1swap
Jun 3, 2024 03:25 PM
mulcryant
Oct 4, 2015 12:18 AM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
