name this part...
Old Feb 12, 2003 | 06:02 PM
DONNA's Avatar
Question name this part...
85gsl, to the rear of the thermostat housing there is a black pushrod plastic thing with a wire and a screw head on it,,,is this the TPS, what does it do and how is its adjusted,,,and what are signs of needing adjustment,,,,
Old Feb 12, 2003 | 06:15 PM
RacerX7fb's Avatar
paradox
Im not quite sure what you are describing...the thermostat is within the water pump.
And since you have a GSL and not an SE, your engine is carbed and not fuel injected, hence no TPS.
Old Feb 12, 2003 | 06:19 PM
85RX7GS's Avatar
Hmm, not quite sure what you're describing, but that "switch" that you move aside when doing the mechanical secondaries mod is the throttle sensor.
Old Feb 12, 2003 | 06:36 PM
DONNA's Avatar
throttle sensor sounds right,,,whats its function, any indications to if it needs adjusting,,,
Old Feb 12, 2003 | 11:08 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
id name it BOB
Old Feb 13, 2003 | 09:53 AM
85RX7GS's Avatar
It is definitely a part of the cruise control system. I'm not sure it serves any other purpose though.
Old Feb 13, 2003 | 10:50 AM
Rx7carl's Avatar
Airflow is my life
Re: name this part...
Sounds like the TPS. Look in the haynes or FSM for adjustment.
Old Feb 13, 2003 | 10:51 AM
Rx7carl's Avatar
Airflow is my life
Originally posted by BadAssRX-7
id name it BOB
Old Feb 13, 2003 | 10:56 AM
Rx7carl's Avatar
Airflow is my life
Im not sure if its tied to the CC system. But I do know its part of the emissions system for acceleration/deceleration controls.
Old Feb 13, 2003 | 11:04 AM
****, if its emissions. Take it off!
Old Feb 13, 2003 | 11:28 AM
NanaimoRx-7's Avatar
How big/long is it? I was thinking OMP rod, but that's just my take on the description.
Old Feb 13, 2003 | 11:29 AM
Rx7carl's Avatar
Airflow is my life
Originally posted by NanaimoRx-7
How big/long is it?
This isint the lounge dude!
Old Feb 13, 2003 | 11:30 AM
Dammit I knew I shouldn't have added /long... you're all bastards !!
Old Feb 13, 2003 | 11:42 AM
JEC-31's Avatar
Plastic Jedi
Beg, borrow, or steal a digi-cam and post a pic 'cause I have no clue.
Old Feb 13, 2003 | 12:02 PM
Redwood's Avatar
Find Racing
****, if you don't know what it is or what it's doing, take it off!
Old Feb 13, 2003 | 01:46 PM
85RX7GS's Avatar
Old Feb 13, 2003 | 01:48 PM
85RX7GS's Avatar
It's gotta be part of the cruise control because when I had it unplugged, the CC DIDN'T work.
Old Feb 13, 2003 | 04:14 PM
Rx7carl's Avatar
Airflow is my life
I didnt say you were wrong, just adding what I knew about it to the discussion.
JJfrankyFC
May 29, 2015 10:53 PM
2jz86
May 5, 2015 09:15 PM
spectre6000
Apr 30, 2015 03:34 PM
ColonelSandersLite
Sep 30, 2013 05:42 PM
