uhh I think I screwed up my car.. help pls...
Old Feb 10, 2003 | 08:38 PM
someone82's Avatar
Angry uhh I think I screwed up my car.. help pls...
Well today I was cleaning up my car and I noticed the cover on the voltage regulator was pretty nasty. So I removed and painted it and forgot about it.
So I start my car up to do some tuning, while tuning it I notice I forgot to put the voltage regulator cover back, so stupid me I go and attempt to the put the cover back on... with the car still running... ZAP
I ground the cover agienst the internals of the voltage regulator.. I quickly shut the car off and look for any blown fuses' etc.. every thing looked ok.. I put he cover back on and start it up...
Well not everything is ok; all my warning lights stay on and my tach is now working as the volt meter full time (reminder 79-80 rx7's have the volt meter as part of the tach and is at use only at start up)! and it's reading 14volts at idle?!!?
did I blow the voltage regulator?
matt
Old Feb 10, 2003 | 08:41 PM
85RX7GS's Avatar
Most likely.
Old Feb 10, 2003 | 08:56 PM
680RWHP12A's Avatar
upgrade your alt to internal style regulator! you want one?$20.00 for 65 amp, its real easy to hook up too , 2 wires and your done! then you can throw away the volt reg.!
Old Feb 10, 2003 | 09:00 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Originally posted by 680RWHP12A
..."you want one?$20.00 for 65 amp," ...
Uhmmm, Where at, dude! I want one of those for 20 bucks!
Old Feb 10, 2003 | 09:09 PM
someone82's Avatar
IF I come down friday... SOLD.... otherwise I want to get my car driving first, so seeing I can't get a new voltage regualtor for a week (both pepboys and kragen).. I'm gonna hit the junkyards tommorow morning before work and get one for a few bucks
matt
Old Feb 10, 2003 | 09:15 PM
680RWHP12A's Avatar
anybody that stops by gets one for $20.00 . i have about 30 of them!
Old Feb 10, 2003 | 09:40 PM
jutny's Avatar
SA all the Way!
did the 80 have an externally regulated alt? cause i dont think mine has the box...
Andrew7dg
Aug 6, 2017 01:41 PM
Chiaszy
Sep 23, 2015 01:43 PM
