Consensus on shutter valve
Old Feb 8, 2003 | 04:27 PM
cveklund's Avatar
I have searched over and over but can't get a definate idea on the shutter valve. I removed the rats' nest with Rx7Carl's tutorial. I have read theat you should plug both of the holes on the shutter valve and then I have read that you leave one open. Can someone please tell me what to do with it and maybe an explanation of why it should be done that way?
Thanks,
Chris
Old Feb 8, 2003 | 04:31 PM
inittab's Avatar
I read your email
All I can tell ya is that I plugged the large vac hose and all my shutter valve woes disappeared.
Old Feb 8, 2003 | 05:10 PM
mar3's Avatar
Administrator
Do as he says, there is a reason....
Old Feb 8, 2003 | 05:13 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
I vaguely recall plugging the large one and leaving the small one open.
Old Feb 8, 2003 | 06:08 PM
mar3's Avatar
Administrator
Exactly... ...except open to the vacuum system and not open air, though...ie., vacuum leak, otherwise....
Old Feb 8, 2003 | 07:29 PM
cveklund's Avatar
Since I have removed the rats' nest, I have to cap off the small one, right?
Old Feb 8, 2003 | 07:35 PM
85RX7GS's Avatar
Re: Consensus on shutter valve
I know how you feel. It's hard to find specifics on that weird device.
I removed the rats' nest with Rx7Carl's tutorial. I have read that you should plug both of the holes on the shutter valve and then I have read that you leave one open. Can someone please tell me what to do with it and maybe an explanation of why it should be done that way?
Thanks,
Chris
I don't know about the little tube - I believe it goes to one of the valves on the rats nest. As for the big tube, I've got that one plugged. I hope I did it right, because I really don't notice a MAJOR difference.
Old Feb 8, 2003 | 07:40 PM
82transam's Avatar
Never Follow
Re: Re: Consensus on shutter valve
I didn't fell much of a difference in power or anything, but mine idles smoother with it plugged. The exhaust reeks quite a bit more but whatever.
Old Feb 8, 2003 | 08:03 PM
Crack Monkey's Avatar
asdf
If the rats nest is removed, why do you still have the shutter valve in place?
It's easy to remove. Just a few screw/bolts. Use some fast dry epoxy to close the holes.
Old Feb 8, 2003 | 09:17 PM
j9fd3s's Avatar
Community Builder
the shutter valve is there to keep the temps in the main cat steady on deceleration, if you have no cats you dont need a shutter valve
mike
Old Feb 9, 2003 | 11:56 AM
85RX7GS's Avatar
Re: asdf
You don't need it. Rip 'er out!
ls1swap
Jun 3, 2024 03:25 PM
scissorhands
Oct 8, 2015 01:17 PM
Rotafuzz
Sep 30, 2015 09:55 AM
