yes!!!!!!!!!!! it started but........
Old Jan 31, 2003 | 02:49 PM
eddierotary's Avatar
back with rotaries
i happy, happy, joy, joy. finally i started. but it doesnt stay running. and i dont have a clue why. it start run for 5 -10 second and shuts down. and i pull the plug out and they are flooded and they are new NGK's. i have the timing in 0 leading and 10 trailing. it sound like it runs out of gas but the spark plug are wet and i put about 3 gallon of 94 octane gas. the only problem i had was the air temp sensor, that the stock gslse one broke and im using a 2g one, does that could be the problem? does somebody have any idea what could be? somebody??? ill get pic as soon i get a digicam
Old Jan 31, 2003 | 11:15 PM
djmickyg's Avatar
it could be your sensor, i know the rotaries with the exhasut heat senor wouldnt stay started if the sesonr was shot becacause the car thought it was over heating.
Old Jan 31, 2003 | 11:33 PM
back with rotaries
this car never had one and before was running great. i think i found the problem but im not sure yet
Old Jan 31, 2003 | 11:44 PM
Felix Wankel's Avatar
Super Newbie
Stock -SE ECU running it?
Old Jan 31, 2003 | 11:49 PM
back with rotaries
yeah, im thinking anyway to take the turbo out too much s**t to work.i just save the money for a real TII engine or car.
Old Jan 31, 2003 | 11:53 PM
Super Newbie
Will it rev up at all or just die? You may have a vacuum leak somewhere.
Old Feb 1, 2003 | 09:33 AM
back with rotaries
it start and idle fine for 10-30 sec and all of the suden just want to die and if i rev it u it wont die but it start missfiring. and i notice on the ground that there a black spot that was coming from the muffler. im gonna do some things to see if i can get it running right and one of them is for vaccum leak.
Old Feb 1, 2003 | 01:13 PM
back with rotaries
well i did a search and i took every thing apart and it look like the gasket of the lower intake to the egine wasnt sealing by the middle plate, so i holpe is only that and will keep searching just in case, ill keep updating
Old Feb 1, 2003 | 08:16 PM
RotorMotorDriver's Avatar
Seven Is Coming
Definalty keep us updated .
~T.J.
Old Feb 1, 2003 | 08:23 PM
jeremy's Avatar
male stripper
you might need to be rotormotordriver's flux capacitor. that will control any stumbling problems up to 88 mph.
Old Feb 1, 2003 | 08:36 PM
back with rotaries
lol, im still searching i found a few leaks specially in the exhaust. ill tell you guy tomorow
Old Feb 3, 2003 | 05:16 AM
Seven Is Coming
Yeah. It lights up blue stock, but another mod I sell will make it possible for it to glow any other color you want...Even multiple colors at once. Since different colors of light are different wave lengths, they will produce different amounts of power. Be careful with yellow...
~T.J.
https://www.rx7club.com/forum/showth...hreadid=150192
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
