How do I run ECU codes?
Old Aug 12, 2001 | 07:04 PM
TonyTurboII's Avatar
Glock Lover
Can I do this with a voltemeter? Is there a site that states what all the codes mean?
Old Aug 12, 2001 | 10:30 PM
Keith's Avatar
Red face
If your car is an '89 or above, all you need to do is jumper the idle set connector (a single green connector on driver's side near the front) to ground, turn on the ignition, and count the blinks. I believe teamFC3S.org has the codes.
If you have an '87 or '88, that's another story. Your ECU is just plain Stupid! It stores no error codes, so unless you are having the failure right at that point in time, there are no error codes. If there are more than 1 error code, you only get the lowest one! You can't read 'em with a voltmeter. You need Radio Shack LED's. For more info, go to 2ndgenrx7.freeservers.com. Select Technical Information, then select Reading Error Codes.
Peace!
Irv, Keith's dad
Old Aug 12, 2001 | 10:33 PM
Suparslinc's Avatar
It's Back!
Yeah you also need to reset the ecu on pre 89's by unplugging the battery, after you've tested for them. The '89-'91 ecu is 6 times faster than the '88.
Old Aug 12, 2001 | 10:38 PM
MasteRX's Avatar
More Than Meets the Eye
http://home.rmci.net/panther/ecu_codes.htm
Here is a good site that tells you what to do and has the ECU codes.
Old Sep 3, 2002 | 06:04 AM
will the newer ECU work in the older cars? I am looking at probably needing to replace mine anyway.....just wondering if I would be better off with the newer one in my 86 n/a...
Old Sep 3, 2002 | 08:06 AM
DaleClark's Avatar
RX-7 Bad Ass
The later fuel injection system is TOTALLY different - short answer, no, you can't use the later ECU.
Dale
Old Jun 9, 2003 | 11:50 AM
warp0007's Avatar
well you could just get like an apexi hp ecu controller and that will alter everything and make it run a lot better and take away conflicitn g[problems. Everything is stand alone there for a majority of information isnt as neccisary
Queppa
Nov 18, 2024 03:47 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
