Wet or Dry CHRA
Old Jan 14, 2003 | 04:34 PM
IAN's Avatar
IAN
Rotary Reborn!
Wet or Dry CHRA
List,
Is it really neceary to run both water and oil lines for a Turbo. I've order a turbo and it only came dry.
What are the benefits. This is for a street driven and sometimes track/drag.
Ian Skacel
Old Jan 15, 2003 | 09:40 AM
eViLRotor's Avatar
Brother of the Rotary
Good question
Old Jan 15, 2003 | 02:50 PM
RacerXtreme7's Avatar
NASA geek
Water keeps the CHRA section cooler. Its not nesserary but is benfitial because your bearings will remain cooler and its real benefits are when you turn the engine off. It will keep your turbo bearings from coke-ing.....or getting a burt oil resin build up on bearing which shortens life. As long as you let your engine run for several minutes before you shut it off your turbo will be fine with a dry center. But I'd always recomend the wet CHRA for maximum durability and longevity.
~Mike.......
Old Jan 15, 2003 | 11:54 PM
Cheers!'s Avatar
Former Rx7 *****
get a watercooled... it will increase the life of your turbo... IAN, go call cherryturbo again... Herman said he can explain some things for u if you like.
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
dradon03
Sep 18, 2015 05:57 AM
younG_Gunner
Sep 9, 2015 08:26 PM
