single setup!
Old Jan 11, 2003 | 07:15 PM
gofast-'s Avatar
single setup!
alright well im finally going to go for a single setup
Manifold: Late Shift cast
Turbine: Garret 60-1 P trim .70 comp 1.00 a/r
Fuel: SX 1000 hp pump , 550cc primaries 1650cc secondaries
EMS: PowerFC
Port: Street
Clutch: OSGiken twin disc & jun flywheel
I hope to get 420 whp with good spool up (max boost before 3600 rpm)
Old Jan 11, 2003 | 07:52 PM
Bridgeported's Avatar
Sounds like a nice setup. Take lots of pics of the build, and videos when you are done, if you can.
Old Jan 11, 2003 | 08:51 PM
gofast-'s Avatar
thx...im contemplating the fuel pump though...if i should just run two in tank stockers also if i should run 1.15 a/r...but that'll effect spool significantly =\ so i might just stick with .70 / 1.00
Old Jan 11, 2003 | 11:37 PM
Go for the two stock pumps - that is what I would do at least. You get about 320lph for flow, compared to the single Walbro which puts out 255lph. Plus buying another stocker, adapting it to fit, and putting in lines/fittings would cost less than the walbro.
I'm not sure if you should run 1.00 or 1.15... I'm not a turbo expert by any means.
Old Jan 12, 2003 | 02:06 PM
gofast-'s Avatar
hmm twin stockers it is...
1.15 a/r would give me slower spool which is a nono but more hp possibility
1.00 a/r is just what i need =)
Old Jan 12, 2003 | 05:21 PM
lv's Avatar
lv
Do you already have your parts.
Im thinking of selling everything. And i have everything.
93 R-1
Vince
Old Jan 12, 2003 | 06:09 PM
gofast-'s Avatar
yeah my parts are on order..i decided to go with twin FD pumps .70 comp p trim wheel 1.00 a/r ..but im making my own manifold
Old Jan 12, 2003 | 06:24 PM
apexkw's Avatar
in slow, out fast!
where did you order the os giken twin plate clutch from? i am trying to order that clutch but nobody around seems to be able to get it.
Old Jan 13, 2003 | 07:13 PM
gofast-'s Avatar
www.jspec.com can get it from you..i bought mine through a friend with 150 miles on it
Shainiac
Jul 17, 2019 02:20 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
armans
Sep 6, 2015 09:02 PM
