boost gauge more accurate on the map sensor or manifold?
Old Jan 10, 2003 | 11:27 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Where did you guys hook up the line for the boost gauge? The map sensor or manifold and which one is more accurate? Also, is there mechanical and electronic versions of boost gauges? Sorry for the dumb question. heheheh
Old Jan 10, 2003 | 11:39 AM
nmo93's Avatar
most guys will tell you to hook it up to the capped nipple on the manifold. i personally wouldn't t into the map sensor to run a boost guage b/c i wouldn't want to mess anything up w/ the sensor. sorry, but i can't tell you which is more accurate. there are both electrical and mechanical boost guages. i would go w/ a mechanical one b/c all you have to do is run the hose off the manifold directly to the back of the guage.
nick
Old Jan 10, 2003 | 11:42 AM
RX7 RAGE's Avatar
Top Answer: 1
nick
hmmm...the thing is..my avcr is hooked to the manifold and my only choice would be the mapsensor..any thoughts on this? thanks
Old Jan 10, 2003 | 11:57 AM
nmo93's Avatar
go out and get a t so you can run both. i just installed my profec b and it came w/ one so i could run both my boost guage and profec b off of the manifold.
nick
Old Jan 10, 2003 | 12:06 PM
RX7 RAGE's Avatar
Top Answer: 1
where would i plug the T? in the manifold or the hose for the avcr or boost gauge? thanks again.
Old Jan 10, 2003 | 12:46 PM
nmo93's Avatar
have a hose come off your manifold to the t, then it just splits from there. one nipple for your avc-r, the other nipple for a boost guage.
Snoopy FD
Dec 8, 2015 01:45 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
