TO hot to start
Old Jan 8, 2003 | 10:32 PM
94Rx-7's Avatar
High on RXtasy
TO hot to start
My car wont start when its hot. like in the mornings or if i havent drove it in a while it will start right up, but if its hot like if i just drove it it wont start. it sounds like it want to start but it wont. does any one know wut the problem is and how to fix it?
Old Jan 8, 2003 | 10:35 PM
94Rx-7's Avatar
High on RXtasy
and also i do have to play with the gas in order to get it started.
Old Jan 8, 2003 | 10:37 PM
RonKMiller's Avatar
Blow up or win
Re: TO hot to start
Two words: spark plugs.
Try that first and then........hmmmmm.. .. all kinds of interesting things to start chasing.
Old Jan 8, 2003 | 10:40 PM
paw140's Avatar
My car does this sometimes (quite a bit now, actually). Could be your plugs. Or, in my case, I think I have low compression and its about time for a rebuild.
Old Jan 8, 2003 | 10:41 PM
paw140's Avatar
Oh yeah, I found a procedure that works great to start my car. If it doesn't fire right up, but only fires and tries to start, floor the gas pedal while cranking it. Mine starts right up when I do this.
Old Jan 8, 2003 | 10:42 PM
94Rx-7's Avatar
High on RXtasy
i just did the spark plugs last week.
Old Jan 8, 2003 | 10:48 PM
RonKMiller's Avatar
Blow up or win
I assume you used the correct heat range.....lemee see if I can pull some info from troubleshooting - stand by for a few minutes.
Old Jan 8, 2003 | 10:50 PM
RonKMiller's Avatar
Blow up or win
New fuel filter also?
Old Jan 9, 2003 | 12:00 AM
Air-Rex's Avatar
paw 140, if you floor it while cranking it won't get any gas,( no signal sent to the inj.) So it might be starting to flood the first time you try starting it.
Old Jan 9, 2003 | 01:24 PM
94Rx-7's Avatar
High on RXtasy
i did the fuel filter in august and when i do put the pedal to the floor it real doesnt want to start but if i play with it it will start, but when its hot it wont satrt at all i have to wait till it cools down.
Old Jan 9, 2003 | 02:51 PM
paw140's Avatar
Yeah, thats what I was thinking too. I just have to get off my lazy *** and do a compression test and eliminate that before I go searching for the gremlins that would be making my engine flood. On a positive note, it has ALWAYS started.
Old Jan 9, 2003 | 02:54 PM
93BlackFD's Avatar
built my own engine
two, too, to
learn english!
Old Jan 9, 2003 | 02:56 PM
maxpesce's Avatar
Ex fd *****
Also Check the BATTERY voltage while cranking - if it drops below 11v then you need a new battery. at that voltage you won't get enough spark to start the car even if it is turning over.
Old Jan 9, 2003 | 08:08 PM
RonKMiller's Avatar
Blow up or win
Excellent advice.
How many miles on the ENGINE and what is the history, mods, etc. Including everything you know about it before you owned it, if you are not the original owner.
The next step is a compression test with a MAZDA BRAND - I REPEAT - MAZDA BRAND compression tester.
If you have high mileage on an engine that has been beat on you probably need a rebuild. Sorry. That's just the way it is......
Old Jan 9, 2003 | 08:16 PM
RonKMiller's Avatar
Blow up or win
Originally posted by 93BlackFD
two, too, to
learn english!
English? like -you know, like, who cares, you know?
I'm sure - for sure, you know?
Life is good when you live in Orlando: THE ONLY PLACE IN THE ENTIRE WORLD WHERE I HAVE EVER FELT SCARED TO GO OUT AT NIGHT! ... and that includes most third world countries.
New Orleans runs a close second. Sorry - that's "Nooh Awhleens".
Old Jan 11, 2003 | 11:56 AM
94Rx-7's Avatar
High on RXtasy
thanks for all the replies. the engine was rebuilt about 15000 or 20000 miles ago no major mods done yet, but i am running at 12 psi and the exhaust was kinda done but im goin to change it soon. im goin to check the battery asap.
Old Jan 11, 2003 | 12:25 PM
paw140's Avatar
Come on Ron. You're scared of New Orleans? It's the greatest place on earth! And it's pronounced 'nah lins'.
Or something like that
Old Jan 23, 2003 | 02:00 PM
94Rx-7's Avatar
High on RXtasy
checked the battery and the battery is good wut else should i check. i had to leave my car at my girls house cuz it wouldnt start at all. i tried push starting it and it still wouldnt start. wut should i do?????????
Old Jan 23, 2003 | 02:10 PM
Mahjik's Avatar
Mr. Links
Next step, IMO, would be a compression test.
Old Jan 23, 2003 | 02:14 PM
94Rx-7's Avatar
High on RXtasy
i figured that. i better prepare myself for the worst "REBUILD"
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
rx7shirley
Sep 2, 2015 02:11 PM
