1600cc installing problem .
Old Jan 8, 2003 | 09:25 PM
to_slow's Avatar
Unhappy 1600cc installing problem .
Can some one help me out ?
I'm trying to install 1600cc inj and fuel rail ,I am having problem with the lower intake manifold the injector is sitting sloppy in the hole .
What do I need to do ,to fix this problem ? I know most of you have the 1600cc in your car and can help out .
Thanks
Dan
Old Jan 8, 2003 | 11:29 PM
Jason's Avatar
The one
Which fuel rail are you using?
You need to remove the stock plastic runner that sits inside that hole. The injector should fit flush against the inside of the manifold hole.
Jason
Old Jan 9, 2003 | 12:02 AM
streetpower's Avatar
You actually have to modify the plastic insert abd the tip of the injector..so the injector will not move ..or feel sloppy.....shoot me a p.m.
peace
sean
Old Jan 9, 2003 | 01:56 AM
A-Spec Tuning's Avatar
Registered User
Re: 1600cc installing problem .
you need to grind down the upper "lip" on the air bleed sockets.
good luck!
Old Jan 9, 2003 | 02:01 AM
fcturbo2's Avatar
huh?..grinding, modifying, and removing???...does this only apply for the FDs?.. I dont remember doing that in my FC rail when i installed my 1600s.
Old Jan 9, 2003 | 09:10 AM
to_slow's Avatar
Well I tryed the grinding thing but the pieces were to old and they cracked .
So what I did ,I put two bigger o rings on the injectors to sill it better and from the looks of it did the job ..
Jason .
Its the k2rd rail that I got from you .
Thanks 4 your help !
Dan
Old Jan 9, 2003 | 10:24 AM
rxrotary2_7's Avatar
using a small piece of 3/8 fuel line may help. i took out the air bleeder. also, if you have the O-rings from the stock primary rail fit over the bottom of the injectors and can help.
Old Jan 10, 2003 | 03:54 AM
fastrotaries's Avatar
W. TX chirpin Monkey
i guess this is for the FD. I got rid of my diffusers fearing that they would just get blown into teh intake tract, anc then cause bad things to happen.
Old Jan 10, 2003 | 12:32 PM
Heath's Avatar
MAGNUM SE7EN
Damn, my 1600's are installed without the modified air bleed sockets. Do I need to modify and install them?
Old Jan 10, 2003 | 01:33 PM
to_slow's Avatar
Well I got them(2-850cc adn 2-1600cc ) installed and started the car .. so it runs fine ..
Thanks 4 all your help
Dan
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
