Boost Leak Survival Guide
Old Jan 8, 2003 | 02:34 PM
Brentis's Avatar
Ok. Seeing how I have been talking to myself on this board for a while now I've tried to perform a few diagnostics on my pfc to asses whether it is working or I have some other problem.
So as you may recall, I can't get higher than 10psi regardless of my pfc settings. Fortunately, I tested to ensure I could control the boost downwards. It is rock steady at 7psi when I tune it for that - with that said - as I understand it - I MUST have boost leakage somewhere.
From the Turbos I have a stock crossover pipe, a greddy smic, and the greddy 2 piece kit going into the turbo. Frankly, I am somewhat amazed that this could be the problem, but I would like to know what everyone thinks I should check out.
As much as I like typing for my health - I hope someone will answer.
Thanks!
Old Jan 8, 2003 | 04:34 PM
LAracer's Avatar
Re: Boost Leak Survival Guide
Originally posted by Brentis
Ok. Seeing how I have been talking to myself on this board for a while now...
I know how you feel...
Are you sure it's a boost leak in the IC piping? Maybe it's a vacuum hose problem, or is that what you meant?
Old Jan 8, 2003 | 05:02 PM
Brentis's Avatar
I have no idea.... I figure it is somewhere in the ic piping seeing how i didn't have the problem b4 I changed my stock ic to a greddy smic
Old Jan 8, 2003 | 05:08 PM
evot23's Avatar
Classy
Connection from the stock IC to the cossover and to the Y-pipe is notorious for boost leak not easily visible. The pressure from boost usually goes through a crack which closes when the car is in vacuum.
I would change your hose connections if you still have the stock ones.
Make sure you didn't accidentally disconnect a hose during install of the Greddy IC.
Old Jan 8, 2003 | 05:34 PM
Fritz Flynn's Avatar
All out Track Freak!
Many times when you have a leak in the intake or ic connections or pipes/hoses your boost gauge will flutter is this happening? Is everything in relation to boost control working properly accept for moving higher then 10lbs IOW is boost building in all gears at the proper point if this is the case then I would say you have a leak somewhere other than your vacc hoses. Are you getting any boost spikes or is it level at 10lbs?
Old Jan 9, 2003 | 07:49 AM
Brentis's Avatar
Thanks for the insight.
--- I have had the "hose-job" done with tieoffs so I don't think (hope) that is the problem. I'll do a visual today to be sure.
--- As far as how the boost is working, it has the feeling that it is being controlled - meaning everything works fine, except it won't boost past .71 max.
My boost curve feels like it is building normally in all gears.
--- Is it just coincidental that isn't going past 10psi or are items (such as the crossover) particularly weak over 10psi?
Old Jan 9, 2003 | 08:13 AM
blackscorpio's Avatar
#1 F0RUM TROLL
Boost leaks are a bitch to diagnose with the stock setup.
Old Jan 9, 2003 | 11:14 AM
adam c's Avatar
Cheap Bastard
If you need/want a replacement crossover tube, I have one that I would let go for cheap. Good luck with the diagnosis.
Adam
Old Jan 9, 2003 | 11:24 AM
Brentis's Avatar
Thanks but I'm not going with the stocker next time around - thinking the polished efini....
Old Jan 9, 2003 | 11:50 AM
Van Sema's Avatar
Bacon
Good luck Brentis ...
Old Jan 9, 2003 | 11:58 AM
Brentis's Avatar
Well - I am really anxious to see how fast it will be - with 12 or 13psi. You said my car seemed pretty quick at 10, so at 13psi I may be able to keep up with you..
rgordon1979
40
Mar 15, 2022 12:04 PM
troym55
23
May 25, 2016 12:42 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
