Power FC Tuning for HP...
Old Jan 5, 2003 | 04:19 PM
TwinTriangles's Avatar
What's an RX-7 ?
Tuning for HP...
Okay when tuning for HP, and Ive already achieved 11.5/1 AFR, is that the most you can do for HP or will manipulating timing more surface more power?
My question is once you achieve the optimal/desired AFR is that all there is ?
Jdub
Old Jan 8, 2003 | 10:43 AM
Badog's Avatar
Re: Tuning for HP...
Jdub
Your assumption is based on a single number. Think of a 20X20 map (pressure x RPM) with a goal for each cell, and transitions not only for each cell but for parameter changes like temperature.
For air density, you can optimize the tuning to produce maximum horsepower, which may mean a AFR of something other than 11.5.
Keep searching and reading...
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
