T66 Install
Old Jan 4, 2003 | 09:18 PM
mark57's Avatar
Temple of Cornd0g
T66 Install
Here's some pics of what's going on........
Old Jan 4, 2003 | 09:21 PM
mark57's Avatar
Temple of Cornd0g
and another
Old Jan 4, 2003 | 09:25 PM
mark57's Avatar
Temple of Cornd0g
Using A/L IC
converted the GReddy SMIC to liquid
Old Jan 4, 2003 | 09:28 PM
mark57's Avatar
Temple of Cornd0g
It's super clean...........
Old Jan 4, 2003 | 09:42 PM
Bridgeported's Avatar
Hey that's looking pretty good so far!
What EMS are you using, and how much boost are you aiming for?
Old Jan 4, 2003 | 10:13 PM
mark57's Avatar
Temple of Cornd0g
Using the PFC and a Jabsco water pump. Everything is mocked up and fitting well. Sending the I/C back to the fabricator on Monday to weld in a fill-tank. Will run 14 psi. Have big HKS Racegate open to ground, but can't find a pic of it.
Old Jan 4, 2003 | 11:21 PM
suganuma's Avatar
no
unless my eyes are failing me, it looks like you are using the standard HKS wastegate....
me and a few others have had problems with it creeping with a ported engine on the HKS manifolds above 7000rpm or so. I notice that you have a custom manifold - not sure what that might do to help or worsen the problem, but you might want to look into the race wastegate from HKS since the piston and dump opening are both quite a bit larger.
-Nic
Old Jan 5, 2003 | 12:02 AM
crispeed's Avatar
'Tuna'
That's a S.F.P. turbo manifold.
I can also remember when they borrowed a 3rd gen single turbo downpipe from me to make a copy of it!
crispeed
87 Rx-7 TII
9.204@150.47mph
2600lbs
un-tubbed
Old Jan 5, 2003 | 12:21 AM
680RWHP12A's Avatar
mark57
very nice setup you have there! should be a blast to drive!!!1
crispeed
his header, S.F.P.??? who is that?looks nice! how much are they? large primaries( looks like in the pic)
Old Jan 5, 2003 | 12:30 AM
suganuma's Avatar
no
sfp stands for south florida performance
and ya, i neglected to mention everything looks very nice and clean!
Old Jan 5, 2003 | 11:16 AM
to_slow's Avatar
Can some one tell me how much is the sfp manifold going 4 ?
Mark57 how much power are you expecting to put down with that set up ?
Thanks
Dan
Old Jan 5, 2003 | 06:10 PM
mark57's Avatar
Temple of Cornd0g
The manifold is about $800 with Jet-Hot coating. It's the manifold Ari Yallon was using, I believe, on his race car. It is very nice. Other manifolds can be had for less but I'm very happy with this one. My goal is to have a lot o' bullet-proof power, if such a thing is possible. That's a refreshed '94 JDM motor from RP. It's not ported - injectors bored out 700/1200 from RC and Fluidyne radiator, fuel pump, PFC, GReddy ProfecB, ss MP, TurboTimer from and installed by RP 2 years ago. PFS cat-back in place (PFS intake, I/C, and PMS Pink 9 sold to my friend who's running an extremely fast RP street-port engine dyno'd by them. I mean his car is outrageously fast on stock injectors and runs great. He also has the PFS software for his piggy back). But I ramble - I'm hoping for at least 390 - 420 RWHP.
Thanks to all for the kind words and I hope to have more photos soon. Mark
P.S. That's Freddie fabbing the turbo oil return pipe - looks like he's been hittin' the sauce. He's the best RX7 and automotive guru, business partner, and friend anyone could have.
Old Jan 5, 2003 | 06:12 PM
mark57's Avatar
Temple of Cornd0g
bump
Old Jan 5, 2003 | 06:31 PM
rotorbrain's Avatar
fart on a friends head!!!
looks like hes been shootin up the damn sauce. . .
paul
Old Jan 5, 2003 | 07:34 PM
setzep's Avatar
Intresting... is it going to be all right making the oil drain from a solid tube? Do you think the expansion and contraction of the manifold is just going to be minimal?
Old Jan 5, 2003 | 08:38 PM
mark57's Avatar
Temple of Cornd0g
I don't think that will affect the tube, I hope....
Old Jan 5, 2003 | 10:23 PM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by 680RWHP12A
crispeed
Yep, that's their Stamp on it. The Primaries are TOO Large, and you lose velocity and spooling slows down.
The only good thing about their manifold is that they are sturdy.
It is heavy duty, but it's definately not Crispeed's. His are downright a work of art.
Old Jan 5, 2003 | 11:08 PM
wanklin's Avatar
Rob
Looks nice. I have a similar setup being installed right now. Maybe we can comp. numbers when we're done.
-Rob
Old Jan 6, 2003 | 10:13 AM
mark57's Avatar
Temple of Cornd0g
You're saying then some noticeable turbo lag as a result?
Old Jan 6, 2003 | 08:37 PM
setzep's Avatar
if you loose anything down low I'm sure you will more than gain it up top where that T66 shines
Old Jan 7, 2003 | 03:56 AM
680RWHP12A's Avatar
the only thing you will be losing is the compitition my friend!!!!!
Old Jan 7, 2003 | 12:38 PM
maybe the manifold is thick-walled mild steel. that could explain w/ it looks so damn big. what's the i.d. on the primaries? anything over 1 7/8 in. i'd say is pushing it if you want decent spool and street drivability. damn this is a lot of overkill for 400rwhp, i've never even heard of someone using a air to water ic for hp this low. i like the whole setup though.
i'm surprised you wouldn't get it ported since the you had the motor torn down anyway. even a mild job would net you a lot of hp w/ a turbo that big.
Old Jan 7, 2003 | 01:38 PM
mark57's Avatar
Temple of Cornd0g
It's my bad
because I was going to do everything to the motor, but some things happened with my health and I wasn't and am still uncertain of some outcomes. So, I'm just getting the car finished. I passed on the porting and the exotic apex seals. I think it'll still be fast. I may build up the motor that came outta the car as it is still good although worn; average compression for 80K mi., but not broken.
Old Jan 10, 2003 | 05:47 PM
allrotor93's Avatar
i am running 850/1600 with my setup. are these too big?
Old Jan 10, 2003 | 05:55 PM
You have plenty of fuel with the 850/1600 set up, even if you up your mods such as going bridgeported, you should still have enough.
They aren't too big though... generally if you tune things right, it's hard to have too much fuel for your rotary. Keep your set up - it's nice.
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
