Oil Trouble
Old Jan 3, 2003 | 11:11 PM
SWAT81's Avatar
8AN5H33
Question Oil Trouble
Ok, now I need some serious advice on which grade of oil to use for my 3rd Gen RX 1993. The previous owner told me to use 20-50 and I know for a fact this can not be possible since its oil used for heavy duty trucks or vans. Does anyone know what's the best oil for my RX?
Old Jan 3, 2003 | 11:28 PM
1bad7-back's Avatar
the previous owner was correct. this is due to the fact that the rotary operates at a higher temperature than a piston motor and also the fact that gasoline mixes with the oil in a rotary therefore dilluting it. stick with the 20w50 or 15w50
Old Jan 4, 2003 | 12:44 AM
turbojeff's Avatar
Do it right, do it once
Dude, if it'll pour into the oil filler neck anything is possible.
Anyway 1bad is right, use 20w-50 unless it is really cold. Fuel does dilute the oil and is normal, the more often you use boost the more often fuel gets in the oil.
Jeff
Old Jan 4, 2003 | 11:00 AM
Ralgh's Avatar
I know I am just restating what has already been said but Tri Point Engineering also insited 20W50 is the way to go. I have been running it since August with no problem.
Old Jan 4, 2003 | 11:08 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
I go with 20w-50 in the summer and 10w-30 in the winter. FD's have high oil temperatures so the heavier oil is also needed for that. This topic has been debated alot around the forum and is old. Use the search function to find more threads on this.
Old Jan 4, 2003 | 03:46 PM
Joker's Avatar
mobil 1 15W/50 if you can afford it, motul 300v competition oil ($13-per-liter)...good stuff!
Old Jan 4, 2003 | 07:59 PM
93blackrx's Avatar
wow I didn't know that, what should I use when breaking in my engine? I know I should search but I'm a lazy slob. I know I should use dino oil when breaking in but what weight?
Matt
Old Jan 4, 2003 | 08:02 PM
Joker's Avatar
use whatever oil you plan to use during the life of the motor and turbos.
for me that's mobil 1 15W/50
Old Jan 4, 2003 | 09:51 PM
93blackrx's Avatar
cool thats what I'll go with, Thanks.
Matt
Old Jan 4, 2003 | 10:58 PM
Nameless's Avatar
Break in your motor with dino oil. 20w50, breaking in with synthetic is not advisable cuz of glazing.
Old Jan 4, 2003 | 11:27 PM
adam c's Avatar
Cheap Bastard
Pineapple racing also recommends using Mobil One synthetic oil. I use 15/50.
Adam
Old Jan 5, 2003 | 11:27 AM
FDjunkie's Avatar
When I used 20w-50 Valvoline my high RPM oil pressure was much higher (maxed the gauge even once fully warmed up) and the engine burned significantly more oil. You could easily see a big cloud of bluish oil smoke behind the car anytime I accelerated hard. I now use 10w-40 Valvoline and just keep it changed regularly.
On a related note, I found that the higher oil presure also contributed to the oil pressure sender failures. https://www.rx7club.com/forum/showth...hreadid=124078
Old Jan 5, 2003 | 12:09 PM
SleepR1's Avatar
Question Huh
Glazing? What is that? Is that burned up oil deposits?
Mobil 1 has a bp of over 300 F! The higher boiling point means it will not burn up and leave "glaze" deposits?
Old Jan 5, 2003 | 12:47 PM
93BlackFD's Avatar
built my own engine
i am running 10w-30...should i switch? live in georgia and temp rarely goes below 30F this time of year
Old Jan 5, 2003 | 01:38 PM
Joker's Avatar
10w/40 or 15w/50
Old Jan 5, 2003 | 02:11 PM
Nameless's Avatar
Re: Huh
I'm just giving it to you as Tripoint and Mazdatrix has told me. If they are feeding me bullshit, then so be it.
Old Jan 5, 2003 | 02:15 PM
SleepR1's Avatar
Oh, ok differing opinion
I'm giving the opinion Dave Barninger of KD Rotary gave me
Maybe it's all
Old Jan 5, 2003 | 02:17 PM
Nameless's Avatar
maybe
Old Jan 5, 2003 | 11:53 PM
SWAT81's Avatar
8AN5H33
So overall Mobil 1 10W-30 is the best choice? By the way my RX has 65k miles on it and when its on idle it smokes alot but after 5mins it goes away. Is this normal? Its white smoke but sometimes it had a slight bluish tint. A mechanic friend told me it doesn't smell like oil or coolant so I have no clue why its doing it.
Old Jan 6, 2003 | 12:16 AM
Rx-7$4$me's Avatar
if its cold where u live, it could just be normal moisture since the exhaust heats up so fast from rotarys
13
Jan 9, 2018 11:19 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
