Pipe Cracked!!
Old Jan 2, 2003 | 01:52 PM
Dragueur's Avatar
Angry Pipe Cracked!!
MIDDLE PIPE from LOWER i/c piping to Y-pipe....CRACKED by filler cap to radiator.
know where I can get another one?? polished one?
Old Jan 2, 2003 | 01:54 PM
GsrSol's Avatar
Z06 powered FD
Greddy 3pc pipe kit.
Old Jan 2, 2003 | 02:04 PM
Dragueur's Avatar
know where i can get them?? RX7store?
Old Jan 2, 2003 | 02:35 PM
jr's Avatar
jr
http://66.216.67.51/subcatmfgprod.asp?0=216&1=330&2=-1
Old Jan 2, 2003 | 02:39 PM
Dragueur's Avatar
that doesnt look like the MIDDLE piece of the LOWER i/c piping to the Y-pipe. is it??? the ONE that is BOLTED onto the filler cap to the radiator(2 bolts on each side of the pipe)
Old Jan 2, 2003 | 02:57 PM
jr's Avatar
jr
Oh, that would be the Y-Pipe crossover tube, you can replace that with the Efini Y-Pipe, you can find that at the RX-7 Store too.
Old Jan 2, 2003 | 03:15 PM
Dragueur's Avatar
so the ONLY way out of this is to get the Y-PIPE.....
I duct taped it...and its starting to melt.
Old Jan 2, 2003 | 03:17 PM
vudoodoodoo's Avatar
I keep thinking "crack pipe"
Old Jan 2, 2003 | 03:43 PM
jr's Avatar
jr
or find someone selling a used stock plastic Y-Pipe. Maybe try fixing the crack with some JB-Weld.
Old Jan 2, 2003 | 03:55 PM
Dragueur's Avatar
vuudoo......need one??
jr..thanks man....but umh, JB WELD work on plastic?? i swore it couldnt hold the pressure when i used it on my plastic radiator?
Old Jan 2, 2003 | 04:09 PM
jr's Avatar
jr
Probably not, but it's better than duct tape. I JB-Welded my ACV together once and it lasted a few months. Obviously getting the Efini pipe would be best, but if you can't afford one just keep an eye on the F/S section here for someone selling a used stock one.
Old Jan 2, 2003 | 04:17 PM
Zoomspeed's Avatar
you can try one of those plastic repair kits they have for radiators
Old Jan 2, 2003 | 05:34 PM
Dragueur's Avatar
I guess I will go to Autozone later and find something.
thanks for the inputs!
Old Jan 2, 2003 | 07:57 PM
Air-Rex's Avatar
They make two part epoxy, that you mix together, Like JB weld for plastic. I've used some on cracked interior parts on the back side. Throw away the duct tape, its for old piece of crap cars.
Eric
Old Jan 3, 2003 | 12:59 AM
flunkysama's Avatar
You can do the poor-mans/ghetto fiberglass repair. Cloth and Epoxy. Its a hassle but it will work better than any jb-weld or epoxy putty stuff.
First, see if you can superglue it or tape from the inside to hold the pieces together. It will make it alot easier to work on. Cut some cloth (old underwear works good) in strips to cover the crack with at least 1/2 inch on each side of the crack. Mix up a bunch of epoxy (use the slow setting type) and saturate the cloth in epoxy so it turns dark and semi-transparent. (just as if it got wet). Then lay it over the crack. Smooth it down with something you can throw away (popcicle stick, scrap shim stock, etc.etc.)
On somethine like this, you'll probably want a second layer (depends on the strength of the cloth). Don't let it dry before you put any more layers on.
It'll look absolutely horrible. But if you put enough layers down, you can sand it and bondo it (I wouldn't). But if the epoxy doesn't break down due to the heat, It'll last.
Something I've done elsewhere that might work here is to drill a series of small holes on each side of the crack. Then sew it up with some nice wire. Smear epoxy over it plug the holes and crack when done.
IMHO, FDs are nice cars and don't deserve fixes like this expect for temp repairs. Post a WTB in the for sale/wanted forum. Do it! Now!
And remeber that Duct tape is the refuge of the weak.
Old Jan 3, 2003 | 04:04 AM
Heath's Avatar
MAGNUM SE7EN
Sending you a pm.
Old Jan 3, 2003 | 12:22 PM
Dragueur's Avatar
damn!!! the duct tape went out on me this morning to work.
i bought me some epoxy...QUICKSTEEL thingy to work on right now on my lunch break. see how long that will hold up.
checkin PM.
heath..u got EMAIL
yetter227
20
Sep 5, 2015 11:57 PM
