Headlight lids
Old Dec 31, 2002 | 09:14 AM
1st7heaven's Avatar
Headlight lids
Ok, I said yesterday I wouldnt do this but I have to show you all the results!! I made the first fiberglass headlight lids, they are not complete yet but they are close. Here is a picture the pair, I hope to be doing them in carbon at some point:
Old Dec 31, 2002 | 09:17 AM
1st7heaven's Avatar
Here is a side view:
Old Dec 31, 2002 | 09:20 AM
1st7heaven's Avatar
Here is a second gen I am making and will be putting the scoop in the 1st gen lid on the right side only.
Old Dec 31, 2002 | 09:37 AM
Rx7carl's Avatar
Airflow is my life
Nice, but not any real weight savings is it?
Old Dec 31, 2002 | 09:43 AM
1st7heaven's Avatar
There is a weight savings but when the stock ones weigh say 1lb. and the new ones weigh say .5lb., no, its not that much. I will weigh them and let yall know. I think the advantage will be carbon and being able to have the vent in them.
Old Dec 31, 2002 | 09:46 AM
85RX7GS's Avatar
Great job! Maybe you can make the scoop so that it lines up with a filtered duct on the inside of the headlamp housing that would allow more air into the engine?
Old Dec 31, 2002 | 10:06 AM
1st7heaven's Avatar
Thats the idea, we will see how it comes out.
Old Dec 31, 2002 | 10:18 AM
Directfreak's Avatar
I am a Jeeper Now.
1st7heaven,
Any luck on the...
Vented Valence?
Old Dec 31, 2002 | 11:12 AM
1st7heaven's Avatar
As you can see, I am very slow with the projects! Once the headlights are done it will be onto the valance.
Old Dec 31, 2002 | 11:18 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
what about the 4 screw holes to mount the lid? and what do you want for a vented fc lid? in glass not c.f.
Old Dec 31, 2002 | 11:31 AM
1st7heaven's Avatar
There are alum brackets resined on to the back side and drilled to match your car.
The FC lids can only be bought through RX7.COM
Old Dec 31, 2002 | 12:09 PM
MarkPerez's Avatar
Tennis, anyone
In your pictures i don't see any mounting 'tabs' on the lids. Also. how about different shapes for the vent. I understand the shape you've cast is very easy to do,
can't you do something more NACA type.so the 'legs'
of the vent aren't so long.
Old Dec 31, 2002 | 12:34 PM
I am a Jeeper Now.
Old Dec 31, 2002 | 12:56 PM
riffraff's Avatar
smog nazi destroyer
Originally posted by Directfreak
1st7heaven,
Any luck on the...
Vented Valence?
work on that hood when you are done with the valence.
Old Dec 31, 2002 | 01:34 PM
1st7heaven's Avatar
I probably wont do any other style, from what I have heard from everyone is the NACA is too big looking and this one is more subtle and sleek looking. I just cant do so many diff. ones.
I guess if I have enough interest in one I would do it.
Oh yah, the brackets are not on this one yet......again, this is the first set out of the moulds. As soon as I get brackets on I will get a pic.
Old Jan 1, 2003 | 04:49 PM
MarkPerez's Avatar
Tennis, anyone
Well if you need some help with designing different shapes let me know, I vent lids, but i'm using all metal.
NACA shapes as well. the mounting 'tabs' are gonna present a problem i feel. because the 'glass' won't be very thick there ,
Old Jan 2, 2003 | 09:26 AM
1st7heaven's Avatar
I resin in metal tabs in to the glass lid.....this is very strong. Other mfg. have been doing it for quite some time and have had no problems. The beauty of the metal in the glass is that you can slightly "bend" the tabs if your car is "slightly bent" to make them straight on your car. As for the originals they were produced off of a straight car.
I will let you know if I need some help on other ducts.
Thanks!!
Old Jan 2, 2003 | 12:04 PM
MarkPerez's Avatar
Tennis, anyone
You know,,while your casting these things, why not cast
your own vents, NACA, and others, people will buy just the vent in glass, and they install them where ever they want, different sizes, and shapes. they are really easy
to do. something to think about..
Old Jan 2, 2003 | 01:56 PM
bcty's Avatar
Boost This!
That hood can only be bought in Japan.. u might be able to find one out here if u get lucky
Old Jan 3, 2003 | 12:13 AM
1st7heaven's Avatar
check out this old thread, I am working on a vented hood of my own.....although not done yet maybe something by this spring!!
https://www.rx7club.com/forum/showth...ht=vented+hood
Old Jan 3, 2003 | 12:41 AM
yayo420's Avatar
That is the pimpist 1st gen body kit Ive ever seen! Who makes that or is it custom?
Old Jan 3, 2003 | 03:00 AM
thorin's Avatar
i love your headlight cover vent. looks waaay better than the naca ones in my opinion. more modern.
Old Jan 3, 2003 | 04:43 AM
rgus30's Avatar
1st7heaven,
Any luck on the...
Vented Valence?
were did that nose piece come from and the flares ?
the nose looks like a subaru rally nose is it ?
randy
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
