Should I Upgrade My Fuel Pump?
Old Dec 25, 2002 | 05:56 PM
RotorMotorDriver's Avatar
Seven Is Coming
I have heard that with the RB exhaust, it would help to upgrade the pump. I have also heard that the stock pump is barely good enough for the stock system. So basically, Im trying to figure out if I should upgrade mine or not...All my mods (the few I have) are in my sig. I think I will eventually, but how necessary is it? I dont really have any problems with fuel availability right now, I just want it for piece of mind, and for when I upgrade my carb setup. I dont know if this will be my next move of not, just trying to gather some info about it and whether its gonna be worth it, or if I should just hold off until I have a different carb setup. Thanks.
~T.J.
Old Dec 25, 2002 | 07:27 PM
REVHED's Avatar
Hunting Skylines
Surely you know the answer to this having been around here as long as you have.
Old Dec 25, 2002 | 09:13 PM
79+80_rx-7's Avatar
Yeah, Mario can give you instructions on what to do with a high quality carter fuel pump
Peace........
Old Dec 26, 2002 | 03:41 PM
79+80_rx-7's Avatar
SO WHEN YOU GETTING A MALLORY PUMP?
Old Dec 26, 2002 | 04:18 PM
mar3's Avatar
Administrator
Peace........
Yes, you
  • throw it into a trash can upon opening the new box...
  • sell it to a racer who will never be on the street....
  • sell it to some sucker that has a gawdawful loud stereo who never turns it down
  • prey upon the feeble-minded and sell it to some newbie unaware of its dB criminal characteristics...
And dead, er...REVHED, is right....you've been at the game too long to be tossing out questions like this...when are you finishing the box in the other rex? STAY FOCUSED ON ONE CAR!!!...
Gotta go Mallory....yeppers....or Aeromotive.......
Old Dec 26, 2002 | 04:38 PM
REVHED's Avatar
Hunting Skylines
When the heck did specific pumps come in to the question? He simply wanted to know whether an upgrade is in order. The answer is abso-******-lutely.
But, reading and comprehension never was your strong point was it now mar3.
Old Dec 26, 2002 | 05:28 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
*If it ain't broke, don't fix it.*
I'm sure you can find something more valid to occupy your time, didn't you have a couple of wires in your engine compartment that weren't covered with that yellow plastic stuff?
(Just givin' you a hard time, buddy.) -WG
Old Dec 26, 2002 | 10:10 PM
bliffle's Avatar
Bottom line, after all the chit-chat, what's the right FP setup for an 85GSL?
B
Old Dec 26, 2002 | 10:40 PM
82transam's Avatar
Never Follow
I'm with wankelguy on this one, if its not starving for fuel currently then use you time money etc on other things, like finishing your air oil cooler swap or something. just my $.02
Old Dec 26, 2002 | 10:41 PM
mar3's Avatar
Administrator
If it's a mild street port with the stock Nikki, then you don't need anything more than a Facet fuel pump out back to cover your fuel requirements...yes, people, they are still available and mucho quieter than a Holley or Carter...if you've got more carburetion than that and a street port or wilder, then it's time to step up to a Mallory Comp110 or Comp140...both will have to be regulated and Mallory has some very nice regulators with vacuum reference ports to compensate for boosted applications...I've got three, but sadly, I'm not using any of them right now because I still haven't unpacked the ProStreet '68 FBird which is stuffed with all my speed parts from "the Move..."
RH, lighten up, dawgster!! As for reading comprehension, I guessed you missed this part of the opening paragraph..."... just trying to gather some info about it..."(RotorMotorDriver,2002)
Need I say anymore?? Besides, I was drawn out of my slumber by the insidious Andrew, owner of three RX-7s and only 15....
Peace out, maihn...
Old Jan 29, 2003 | 09:47 PM
Seven Is Coming
Ok guys...I finished my air/oil cooler swap, and am looking into fuel system upgrades this time for real. Im thinking Holley blue with the reg, but from reading Pauls site and searching here quickly, it seems the Carter is the winner? What do you run and/or suggest?
~T.J.
PS - I found my old thread rather than posting a new one, arent you all proud?
EDIT: Whats Mar3 got against Carter pumps?
Old Jan 29, 2003 | 10:00 PM
jutny's Avatar
SA all the Way!
Originally posted by RotorMotorDriver
<snip>
well, they are loud.
it dosent bother me, but i'm used to cars that make loud and annoying noises (read, old exhaust on my Chevelle... leaked like a bitch)
even mounted with the rubber isolators, it's still loud inside the car, but with the radio on it dosent bother me, and the sound is kind of normal after a while.
Old Jan 29, 2003 | 10:03 PM
Winnipeg85GSL's Avatar
I don't think its very necessary at the moment, but maybe when you mod a bit more. I still can't manage to drain the bowls on my car and I think it sucks down a bit more fuel.
Old Jan 29, 2003 | 10:09 PM
Seven Is Coming
Haha. Yeah, well Im looking into fuel because a friend finally paid me the money he owes me, which means Im looking into Webers as well . So I was thinking the generic Carter "silver", the Holley 1-4 PSI and the Yaw gauge. But, thats assuming Im supposed to run a DCOE at 1-4 PSI .
~T.J.
Old Jan 29, 2003 | 10:16 PM
jutny's Avatar
SA all the Way!
well, good luck finding out.
RB reccomends 4.5psi for their DHLA's... basically the same carb as a DCOE.... but a lot of people around here say that anything over 2.5psi was too much for their setups.
i think you're gonna have to do what i have to do, get the 4.5-9 psi reg, and get the other spring to make it 1-4psi if you need it. And then just mess with it until it's right
and if you have any luck figuring out how to order the Yaw gauge, let me know, cause i've been trying for a while.
Felix Wankel's Avatar
Super Newbie
Carters aren't THAT loud. Try listening to a Weldon fuel pump. Those are loud.
Old Jan 29, 2003 | 10:34 PM
mar3's Avatar
Administrator
And an open header on a V8 ain't THAT loud when you compare it to a rex open tube exhaust "header"...
...it's all relative, so why put up with racket you don't have to when a better alternative fitting for the 21st Century exists on the marketplace?? Delivering precious pulse-free gerotor-delivered juice for your road terror. Hmmm??
Old Jan 29, 2003 | 11:16 PM
REVHED's Avatar
Hunting Skylines
Yeah, but how high do you rev that thing?
Plus it depends on the size of the float bowls as well. The Holley probably has fairly large float bowls.
Old Jan 29, 2003 | 11:25 PM
Seven Is Coming
Like what? Thats what this was about after all . But to be honest, Im young and the noise wouldnt bother me anyway. Hell, my differential makes noise, the exhaust is loud, I have a stereo, my windows are down, etc.
~T.J.
Old Jan 30, 2003 | 12:15 AM
I guess you have a point. The highest it's ever revved was 5750 at about 95 MPH if it makes any difference.
Old Jan 30, 2003 | 12:21 AM
mperformance's Avatar
rotor it's just a matter of $...
carter = $$
mallory = $$$
both will do...you decide. I got a carter NOW (year 2003)...had a mallory on another car. Holley on another. Both whatever your decision I say you change the stock one.
Old Jan 30, 2003 | 12:25 AM
TheTwinTurboRX-7's Avatar
Carter is indeed loud. Have one with little to no sound deadening in the back and it scares my friends. I love it though, and when I get a radio in the car it won't be a big deal. I love having people ask me, "What the hell is that??"
Old Jan 30, 2003 | 12:38 AM
Seven Is Coming
Haha, I have nothing from behind the seats back .
~T.J.
Old Jan 30, 2003 | 12:40 AM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
The Carter is an awesome pump, it's just fine. Sure it's a little loud.... but it's hardly a big deal - if that bothers ya, spend the extra $$ I guess.
Bottom line to me, is that a fuel setup is pretty cheap as far as mods go, and you'll need it for sure somewhere down the line.... so might as well set it up. Also, it does make a little difference even with the stock carb and full exhaust.
I'd say go for it!
Old Jan 30, 2003 | 01:01 AM
Seven Is Coming
Everyone keeps saying to spend the extra money, but no one is saying on what...Did I just miss it?
~T.J.
