Haltech First he won't start now he won't stop
Old Dec 17, 2002 | 08:16 AM
buddah9543's Avatar
Just put in a E6k. But couldn't get it to start. So then when with the haltech TPS along with the connectors. Now the car starts up alot easier but once it starts it reves up like nothing i have seen before and i m not on the gas. I didn't change anything accept the TPS and the connectors. But everytime i try to start the ar even when cold it will start up quicker and just start to rev 1000rpm, 2000rpm, 3000rpm etc. until i just shut it off. I m hoping anyone might have had this problem and might know. Any help would be appreciated.
Thanks
Old Dec 17, 2002 | 02:37 PM
Styk33's Avatar
Haltech E6K
Arrow
Sounds like a mechanical problem to me. See if something is messing with the butterflies/throttle body. Is your throttle cable snagged on something?
Old Dec 17, 2002 | 02:42 PM
buddah9543's Avatar
yeah i checked that and the screw for the butterfly and it was off a bit so i closed it and put everything back. Now i m trying to get it started again. I wish we all could share our maps on this board.
Old Dec 23, 2002 | 04:57 PM
Styk33's Avatar
Haltech E6K
Arrow
You can email them or attach them as a file.
Styk33@ricemobile.net
Although I am busy with the holidays, so it would be a week or so before I can seriously look at a map.
Old Dec 30, 2002 | 12:27 AM
jetenginedoctor's Avatar
Dyno Guy
Your map has little to do with whats causing your engine to race. I'd be concerned that the TPS sensor is somehow not allowing the throttle to close against the idle stop. Physically remove the TPS from the throttle body, but don't disconnect it. Make sure that the throttle rests against the throttle stop/adjustment screw, and try again to start the car. If it still races with the throttle against the idle stop, you've got an induction leak somewhere. Time to hunt for a vacuum leak.
BK
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
smikels
Aug 18, 2015 01:26 PM
