Leaky Rear-end
Old Dec 16, 2002 | 03:46 PM
fatboy7's Avatar
Got Boost?
Question Leaky Rear-end
My SE parts car that I'm stealing the suspension from, I've noticed has a leak in the rear-end. Its kind of off and on, for weeks it won't leak much, then all of a sudden I notice the pavment under it is wet with a new pool of gear oil... Has anyone had problems with a leaky differential, and what did you have to do to fix it?
Old Dec 16, 2002 | 04:23 PM
680RWHP12A's Avatar
check the bolts that hold the 3rd member in .... they vibrate loose causing the rear end to leak....just tighten the bolts , that should fix it..... if it still leaks you will have to pull the 3rd member, and re-silicone seal it...
Old Dec 16, 2002 | 04:49 PM
fatboy7's Avatar
Got Boost?
That sounds simple enough. I'll give it a try, Thanks.
Old Dec 16, 2002 | 04:56 PM
851stgen12a's Avatar
Off riding sportbikes!
I had the same problem on my 85GS. would tighten the bolts down and then a week later it would be leaking again.... After a few times, I forgot to put gear oil in my rear end.... Locking up the rear wheels at 80Mph isnt fun....... Make sure you keep a close eye on the gear oil!!.
Old Dec 16, 2002 | 05:08 PM
680RWHP12A's Avatar
if the bolts keep comming loose use locktite(the green one) thats the high temp one...... the bolts will never come loose again! its available an any auto parts store for cheap
Old Dec 16, 2002 | 09:15 PM
Yea I know that know.... didnt before I blew the rear end up.....
FC_DREAMS
20
Sep 22, 2015 09:43 PM
BoominRX7
Nov 30, 2001 10:49 PM
