sealing rear taillamps??
Old Aug 6, 2001 | 08:55 PM
brownmound's Avatar
Anytime baby!
Lightbulb sealing rear taillamps??
I have an 84 GSL-SE which has been subjected to 20+ days of 100+ degrees of central Texas heat. It appears to have gotten to the left tail lamp, as the glue which holds the lens to the assembly has given, dried up and lost it's hold. After I clean all the old glue off, what kind of glue do you think is best to glue it back on? Seems like a high temperature hot glue might do the trick and be the easiest to apply...though I'm not sure of it's durability.
Any ideas?
Old Aug 6, 2001 | 09:57 PM
Suparslinc's Avatar
It's Back!
I dunno, maybe a silicon based caulk?
Biggest thing you need to look out for now is water vapor getting trapped in there and fogging up your taillights.
Old Aug 6, 2001 | 10:01 PM
Denny's Avatar
Well, Buckaroo...
You may wanna try some clear silicone, or try Automotive Goop.
I used Automotive Goop on my wife's Honda, gluing the protective trim in place around the windshield. That trim takes a lot of punishment, heat, cold, rain, snow, and air force...Lots of air force. I'm pleased to say that it's held well with no ill effects.
Denny, from the 'ol corncrib...
Old Aug 6, 2001 | 10:18 PM
Acuspeed's Avatar
I'm with Denny ... I use RTV silicon for almost everything. Putting my old sneekers that fit *just right* back together, putting my teeth back in after driving in Michigan, sniffing on occasion...okay, so I only actually did the first one
Oh, and of course all the automotive uses...
Old Aug 6, 2001 | 10:32 PM
JoseReyes's Avatar
RicanRider
Talking
You can use a glue gun, but be very careful because once you glue it it's permanent....
Old Aug 7, 2001 | 02:47 AM
MarkPerez's Avatar
Tennis, anyone
Or Maybe Visit Your Local Junk Yard,And Replace The Tail Light
With One In Better Shape,And While Your There,You Can Get
All That Other Stuff You Need For Your Car
Old Aug 7, 2001 | 07:47 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
well im with the sil. i pulled apart a set of tail lights to make clears and then hot glued it back.... that crap didnt hold 2 weeks. also what ever you use make sure it doesnt have lots of fumes, i had to reglue 1 on my 81 and the sil foged the cover... thinking it was water vapoer i removed it and it was not water but a white hase.... i was made
Old Aug 8, 2001 | 08:28 PM
brownmound's Avatar
Anytime baby!
OK- so it looks like hot glue is not a good idea, and it appears that a lot of people recommend silcone. Can anyone recommend a silicone that doesn't emit a lot of fumes. I don't want the lenses to haze up....any suggestons?
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
