how to get pully off alternator
Old Dec 8, 2002 | 07:55 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
anyone have a good proccess for gettin the pully off the laternator, I can't get the axle to not move while I try to turn the pully nut. any sugestions?
Old Dec 8, 2002 | 08:01 PM
Turbonut's Avatar
https://www.rx7club.com/forum/showth...and+alternator
I use an air impact..Electric will work also.
Old Dec 8, 2002 | 08:09 PM
c00lduke's Avatar
well what i did was stick a screwdriver through it and use an impact and it came right off. I'm not sure if it was good to do but havnt seen any problems yet.
Old Dec 8, 2002 | 08:33 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
hmm, I'll try that too, but my 'impact wrench' will have to be a hammer-and-wrench :-)
Old Dec 8, 2002 | 08:35 PM
twinturboteddy's Avatar
Grumpy Lurker
GO to any mechanic
And have them take off the pulley.
Damien, if this is for your polishing job you want me to do.
Bring your alternator to an alternator shop in your area and let them take it apart.
If you have no experience taking it apart, don't try it.
Old Dec 8, 2002 | 08:37 PM
RonKMiller's Avatar
Blow up or win
Old Dec 8, 2002 | 08:40 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
yeah TTT, it is for the polishing job....I havn't herd back from my PM to you on the polishing but let me know the difference in cost between sending it together vs just the shells. I know it will save some on shipping because of the weight difference.
thanks...
Old Dec 9, 2002 | 01:43 AM
I may be wrong but, I had to do an A/C clutch before and I used a small bearing puller to get the pulley off. It was easy
Old Dec 9, 2002 | 01:47 AM
aReX-7's Avatar
An impact is the only way to go. Hammer dosn't work.
Like others said, take it to a shop and give them a 5 spot and they will do it in 2 seconds.
Old Dec 9, 2002 | 04:39 AM
jspecracer7's Avatar
1JZ powered
Impact wrench. Do NOT stick a screw driver in to stop the wheel from spinning...the impact wrench will take it off without anything holding the pulley from moving.
Captain Hook
13
Oct 4, 2015 06:35 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
