What is the difference between 93 cali ecus and 93 non cali ecus?
Old Dec 8, 2002 | 01:27 PM
777rx777's Avatar
Im going to try and buy an m2 non cali 93 ecu for my 7 off of a fellow forum member. I live in cali, does that mean my car has the cali ecu? How will my car run with a non cali ecu? any check engine lights?
thanks in advance
chris
Old Dec 8, 2002 | 01:31 PM
JONSKI's Avatar
5yr member, joined 2001
The only difference I know of is that the cali ECU's use an electronic EGR that will cause a "check engine" light if it is unplugged or malfunctioning. That means if you have a non-cali ECU, then you can eliminate the EGR without causing the "check engine" light.
Old Dec 8, 2002 | 05:29 PM
rynberg's Avatar
You can look at the emissions placard on the underside of your hood to determine whether or not you have a California model or a federal model. You can use a non-cali ecu in a cali car but not the reverse. Or if you have a 95, it doesn't matter, because 95s don't have an electronic egr valve.
Old Dec 8, 2002 | 07:50 PM
adam c's Avatar
Cheap Bastard
I live in Ca. I bought my car from a guy that lived in Ore. It was originally on the east coast. Noproblems with smog or anything here. I would assume that an out of state ecu would be fine.
Adam
Old Dec 9, 2002 | 12:16 AM
777rx777's Avatar
I just checked under my hood, and my car does have the cali ecu.
so my question,
If I buy a 93 non cali M2 ecu, Will it make my check engine light come on? How will it run in the cali model?
thanks again guys
chris
Shainiac
Jul 17, 2019 02:20 PM
Spirit Rx-7
Mar 14, 2016 12:36 PM
Captain Hook
Sep 22, 2015 01:12 PM
Ian_D
Sep 6, 2015 10:38 PM
