What's best plug for FD?
Old Dec 7, 2002 | 09:55 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
Red face What's best plug for FD?
What's best plug to put on FD? I've heard the copper ones are the best conductor, but don't last too long at all. Then theres platinum, but it wont conduct as well as copper but lasts much much longer. And I haven't heard much about iridium. Please tell me the company and type, personally I was looking at bosch platinum +4 for it. Not sure if they make em for the FD but I can check. Thanks for any posts.
Old Dec 7, 2002 | 09:58 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Get the stock ngk platinums for the FD. They're the best to use. Use 9s all around if you are modded.
Old Dec 7, 2002 | 10:17 PM
What kind of price do you pay? THe cheapest I can find is 9.50 for platinum and 7.50 for regulars.
Jim
Old Dec 7, 2002 | 10:22 PM
RX7 RAGE's Avatar
Top Answer: 1
Jim
That price sounds about right.
Old Dec 7, 2002 | 11:21 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Can you still run 9' all around even if you are near stock?? I have intake, DP, CB just so you know exactly what I'm talking about.
Zach
Old Dec 7, 2002 | 11:29 PM
YayeR's Avatar
yes I will have same mods add a MP and ECU.. i have the same question
Old Dec 8, 2002 | 02:01 AM
TomsRX7's Avatar
I live in CA, literally around the corner from XS Engineering, and when they dyno tuned my car, they recommended HKS Irridium plugs.
Old Dec 8, 2002 | 02:48 AM
spurvo's Avatar
don't race, don't need to
I'm running VERY stock (DP only!) and I ran all 9's for 500 miles or so. Pulled em and the leadings were pretty fouled. Put in the 7's and had more power, and after 500 miles, they look just right. Light mocha brown
Running the NGK's BTW. Not platinum...
Old Dec 8, 2002 | 08:36 PM
RX7SpiritR's Avatar
No, haven't started it yet........well I drove it around the block today and it still running like ****, and it kind of makes sense that a plug is fouled or a wire is off, because it's only revving to like 4000 RPM's. I'm going to check connections and ignition coils and of course replace plugs just to be sure which is why I asked this question. Thanks for asking though and I'll let u know when I get it fixed and working again.
Old Dec 8, 2002 | 08:38 PM
RX7SpiritR's Avatar
Hey spurvo, then I take it you're running 7 NGK coppers? Cause if you are then I will use 7's all around cause all I have is dp too. Just to make sure, u got 7 NGK coppers, let me know. Thanks.
Old Dec 8, 2002 | 09:03 PM
striker's Avatar
yeah dp and airbox here. i might try those 7 nkg. same question as above. are they the coppers?
Old Dec 8, 2002 | 11:11 PM
nmo93's Avatar
hey rx7spiritr,
check this site out, it's a comparison of different spark plugs. should help you out in your decision:
http://www.silverbulletrx7.com/plugs.html
nick
Old Dec 8, 2002 | 11:54 PM
spurvo's Avatar
Ooops! Meant to say 9's in the trailing, 7's in the leading, just like the manual says. I tried 9's all the way around, but the electrodes were fouled on the leadings after 500 miles or so because the leadings were too cold. So use the stock config for now. The all 9's trick is for heavier than 10 lbs boost high temp work, where they can help reduce the risk of lean burn detonation. In our stock set ups, we a) don't really need the protection as much, and b) really don't want the fouling that comes with all nines.
All 7's will run too hot. You run the risk of detonating if/when your car is up and running properly Good luck, man! You'll get it...
Old Dec 9, 2002 | 12:00 AM
EviLPeNeviL's Avatar
Can't live without boost.
I'm running all 9s right now and I have a catback...... Is that alright for my current setup?
Old Dec 9, 2002 | 12:16 AM
spurvo's Avatar
Drive 300 to 500 miles and pull the leading plugs (the easy ones!). If they're light brown, you're good to go. If they're black and/or sooty looking, put in a hotter plug.
Old Dec 9, 2002 | 02:25 AM
toddp31's Avatar
7's and 9's for stock or the winter. It all depends on what type of driving you do. If you are idling alot sitting in traffic go with 7's and 9's. If you are driving fast everwhere you can get away with running 9's or 10's. I am running a HKS Irridium all 10's. They do foul out, but they are worth it when you need the extra power. I will spend the extra cash,avoid detanation at all costs!!!
Old Dec 9, 2002 | 06:39 AM
YayeR's Avatar
ok so with a full exhaust, intake, radiator, and ecu should i run 9s or 10s ?
wretchedegg
Nov 19, 2025 03:07 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
