ball bearing turbo question
Old Dec 6, 2002 | 03:39 PM
eddierotary's Avatar
back with rotaries
how manny miles thoes a ball bearing turbo last? more that a regular bearing turbo?thanks
Old Dec 7, 2002 | 03:29 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
less friction = less wear = longer life.
Old Dec 21, 2002 | 05:44 PM
ZoomZoom's Avatar
SEMI-PRO
It would depend on a few factors. Some of them are how much boost will you be running? Is that amount of boost within the particular turbos effciency range? Also is the turbo water and oil cooled or just oil cooled? Even conditions such as type of oil used and use of upgraded oil coolers can impact how long a turbo will last. A general yes or no wont answer your question without knowing many other factors and variables. Any turbo can fail early due to defects or foreign material getting into it. As a general rule your turbo will last longer than your motor when your adding a turbo that makes 500+HP to a motor designed to make 255.
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
Engine stand ready
Aug 14, 2015 10:26 PM
WyomingTII
Aug 13, 2015 10:42 AM
