losing power at 6500rpm in first??
Old Dec 5, 2002 | 09:37 PM
DSM
Question losing power at 6500rpm in first??
man my fc (s5) is losing power in first gear at about 6500 rpm, all i have done to my car is gutted the cat., added intake, and took out the secondary butterflies but i havent removed the shaft yet. could it be that the shaft is causing turbulance?? i dunno, please help!!
keegun
Old Dec 6, 2002 | 06:49 AM
Jimmy325i's Avatar
No longer cares
Does your VDI still work?
Old Dec 6, 2002 | 12:03 PM
bottlejockey's Avatar
since you gutted your cat you may not have enought backpressure to open up your six ports. I have a '90 GTU and I had to open up my six ports after I gutted my cat and put on exhaust. But if that is the case you would lose power in every gear not just first.
Old Dec 6, 2002 | 12:21 PM
kleach18's Avatar
Just Looking Around
Only the S4(86-88) FC's open the aux ports by back pressure. It could just be that you car is slowly dying.
How many miles, how's the cpmpression? More info on the car?
Old Dec 6, 2002 | 12:36 PM
Jimmy325i's Avatar
No longer cares
VDI stuck in the low position maybe?
Old Dec 6, 2002 | 01:44 PM
silverrotor's Avatar
The remnant of the shaft you left behind, when you removed the Secondary Plates, has nothing to do with your car losing power.
Old Dec 6, 2002 | 02:09 PM
kleach18's Avatar
Just Looking Around
Is it just in first gear? It may be your transmission or maybe even your clutch.
Old Dec 6, 2002 | 02:57 PM
Pinfield357's Avatar
do you still have your air pump???
Old Dec 6, 2002 | 10:12 PM
DSM
yeah i still have my air pump, but when i added intake i bought a smaller filter to put on the air pump hose. what is the VDI?? im not sure about the compression, i just bought the car during the summer and had to fix it b/c i bought it wrecked and i just completed it. it has 127,509 miles on it. its about time to rebuild her any ways. i am pretty sure it is only in first, it hasnt happend in any other gear. Bottlejockey....how did you open your six ports... well this is all for now, please help
Old Dec 6, 2002 | 10:13 PM
DSM
o yeah, earlier today i did 3 runs. 2 of the runs pulled back at 6500 and 1 ran strong the whole way.... think it may be a vacuum leak??
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
