Stock TT and boosting
Old Dec 5, 2002 | 06:10 PM
sajazzman007's Avatar
I was just wondering how much can you possible boost safely on the twin turbos without blowing them up or the engine? I heard that each stock trubo has the possiblity of a 15 lbs each??
jon
Old Dec 5, 2002 | 06:16 PM
Snook's Avatar
Tony Stewart Killer.
I believe that anything over stock boost hurts the turbos since they were designed for 10 psi or a little less
If you want the life of the turbos to be almost like normal I would stick from 10-12 psi
The motor can take rediculous amounts of boost safely if you provide enough fuel. 20 something is what single turbo guys run when they want to be at their fastest and I've heard even more than that.
good luck
Snook's Avatar
good luck
rynberg's Avatar
Without an ecu = max of 10 psi
With an ecu =
running higher boost depends on your other mods, if you don't have an intake and less restrictive exhaust, you will melt your turbos trying to run higher boost.
For daily driving, 12 psi is probably the practical limit, assuming you have an intake, intercooler, downpipe, and cat-back. 14-15 psi is the limit for meaningful power increases, after that, the power doesn't increase much and you will kill your turbos quickly.
Old Dec 5, 2002 | 06:30 PM
utrbo mags lastest issue
i was reading turbo mags lastest issue and it talks about the one rx-7 that belts out 420 on the HP with stock eternals almost. the only thing i actually seen that was aftermarket was in smic, airbox, exhaust... how is that even close to posible and he was boosting i think it was 18 lbs??? i encourge all to check it out it is pretty intresting column
Old Dec 5, 2002 | 06:51 PM
rynberg's Avatar
It is impossible to hit 420 hp at the wheels with the stock twins, I'm sure they meant 420 FLYWHEEL hp.
If you have a streetport, you could run 12 psi daily and have about 320-340 rwhp and it would be pretty reliable. You could always crank it up to 14-15 psi and be making 350-370 rwhp for racing (provided you have the fuel upgrades and tuning of course).
Old Dec 5, 2002 | 07:23 PM
af908's Avatar
from what i hear don't go above 12 psi on stock fuel system and intercooler. The stock twins can handle up to around 15psi with fuel+IC upgrades but my guess is they wont last very long running that much boost
Old Dec 5, 2002 | 07:30 PM
I remember reading about an FD that was featured in Import Tuner this month. It sucks for most thing (less oggling girls...last month's cover girl has a monster rack - check it out ) but everynow and then I can get some looks a silvia or two. Anyways, this month had a riced out FD in it, and the tuner company said that the car produced about 420whp on the stock twins at 15psi. So im thinking....time to blow the bull#$*@ alarm, then I say who the tuner was......PFS and it all made sense, I just laughed.
-Ben
Old Dec 6, 2002 | 05:35 PM
af908's Avatar
-Ben
hahhaha was that the one with the stainless-steel braided air hoses??hahha that things hideous lol
Old Dec 6, 2002 | 06:17 PM
thats the one , my friend is a honda boy. We were chillin at his house after class when he showed me the magazine, he was like you like RX-7s, there is a PHAT one in there. I took one look at it and laughed....this thing is a POS I said. Then I had to read the article so I could informatively flame it , those honda boys .....
[no offense to you honda boys that actually know about the workings of a car, and have taste of course ]
-Ben
Old Dec 6, 2002 | 06:48 PM
af908's Avatar
yup i think it said it was running 17 psi on the stockers that cant be too good for them lol
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
TerryD
Aug 23, 2015 07:40 AM
