13 or 16 PSI cooling system?
Old Dec 3, 2002 | 01:20 AM
Zoomspeed's Avatar
Is The FD a 13 or 16 PSI cooling system? I dont ahve my orginal caps anymore. I was looking throught he computer at work (autozone) and if I put in 93 it tells me it need s 13 PSI cap, but if I put in 94+ it says a 16 PSI cap.
I dont' trust autozone computers too much for our cars though. it calls a 93 rx7 a 4 cylinder turbo engine, and it list a spark plug gap of .040"
Thank for any help.
Old Dec 3, 2002 | 03:17 AM
lone wolf's Avatar
It's 13 in the US, but for some reason, in Japan, they have lots of 16. Most of the ones that are advertise in the Japanese RX-7 magazine uses 16. I guess you can go either.
Old Dec 3, 2002 | 09:53 AM
rynberg's Avatar
Buy (or download for free) a friggen' owner's manual for christ's sake!
The original cooling system pressure was higher. I believe Mazda lowered it in 94 to 0.9 bar (13 psi) as part of a recall.
Zoomspeed's Avatar
any reason why I chould go with one over the other?
Old Dec 3, 2002 | 09:54 AM
Zoomspeed's Avatar
HAHAHA sorry. I forgot I have that.
Old Dec 3, 2002 | 11:23 AM
Bally's Avatar
Hi
Just a heads up about going higher than the original 13psi cap. I am a strong believer that it is best not to mess around with such things as water pressure caps due to the fact that going higher will only result in the pressure (should it exceed 13psi) being placed somewhere else and this somewhere else is more than likely to be the water seals. Hence, stick with the 13!
Bally
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
dillrx7
Sep 7, 2015 09:38 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
