finally, the engine's out (some pic's)
Old Dec 1, 2002 | 09:46 PM
xstacy7's Avatar
I love when things work
I finally got around to hooking up the digital camera, so here's some pics
Old Dec 1, 2002 | 09:48 PM
xstacy7's Avatar
on stands
Old Dec 1, 2002 | 09:51 PM
xstacy7's Avatar
in labor
Old Dec 1, 2002 | 09:52 PM
half past twelve's Avatar
why is your gas tank door open? lol
xstacy7's Avatar
ah, it's finally out
Old Dec 1, 2002 | 10:00 PM
xstacy7's Avatar
here's a pic after I took a break from taking things off
Old Dec 1, 2002 | 10:03 PM
xstacy7's Avatar
waiting for her christmas present
Old Dec 1, 2002 | 10:06 PM
xstacy7's Avatar
last engine pic (before the rebuild at least)
Old Dec 1, 2002 | 10:09 PM
xstacy7's Avatar
my garage
Old Dec 1, 2002 | 10:16 PM
xstacy7's Avatar
release pressure, dunno
Old Dec 1, 2002 | 10:23 PM
xstacy7's Avatar
anyone got any idea's of what I should do as far as mod's go? Any comments welcome
Old Dec 1, 2002 | 11:13 PM
paw140's Avatar
I see so many pictures of FD's without engines, or in various stages of engine removal, it's depressing. Someday it'll be my turn
Old Dec 2, 2002 | 01:14 AM
legendr35's Avatar
Get a nice aggressive street port and a single turbo vroom
Old Dec 2, 2002 | 01:37 AM
turbojeff's Avatar
Do it right, do it once
Gas cap comes off otherwise it is possible to have fuel constantly flowing out of the fuel lines. Not a good thing to have fuel constantly dripping, wife hates the smell and drop a steel wrench in a puddle of gas on a concrete floor=FIRE.
xstacy7. Good job!
Here are a couple of pointers to others. Pull the engine with the trans, it is easier. Wiring is easier to deal with along with the starter, clutch, clutch slave, aligning the input shaft, etc, etc.
Leave the hood on the car. I've done it at least 10 times, hood can stay on the car to R+R engine and trans.
Jeff
Old Dec 2, 2002 | 01:48 AM
JONSKI's Avatar
5yr member, joined 2001
Thanks for the pics.
Thanks for the tips.
Old Dec 2, 2002 | 06:57 AM
Rated R1's Avatar
Oji San
Those are good tips but some people cannot get the car high enoug to remove the engine and transmission still mated.
Old Dec 2, 2002 | 07:09 AM
mks's Avatar
mks
High enough? If you can get it high enough to get to the PPF bolts and to remove the prop shaft, you're done. You don't need height to pull the package, I actually had to lower the nose about 8 inches (from where it was while I was unbolting stuff) to get the engine mounts to clear the front when it all came out.
Old Dec 2, 2002 | 07:24 AM
vudoodoodoo's Avatar
Good luck man!
Old Dec 2, 2002 | 07:30 AM
ttpowerd's Avatar
HARRRRRRRRR
Clutch, flywheel, radiator, aluminum AST, and then anything else you can afford like injectors, single turbo, etc.
Looking good
Old Dec 2, 2002 | 11:20 AM
xstacy7's Avatar
thanks for the tips, Turbojeff-it's kind of late to pull the engine with the tranny attached, since it's already apart. I'll have to try it on another 7 because I don't want to do it again on mine. Thanks for the tips though. ttpowered-I am giong to get all of the above except for the injectors, single turbo and AST, cause I already have that. I'm gonna stick with the twins for now. I'm thinking of chroming my UIM~any ideas on that? Keep posting, Thanks
Old Dec 2, 2002 | 11:36 AM
RX7SpiritR's Avatar
The Spirit of FLUFF!
downpipe and all relability mods....please reliability! That's what I'm in process of right now.
Old Dec 2, 2002 | 11:37 AM
turbojeff's Avatar
I know it was late, that is why I said a tip for others.
RatedR1, high enough? You don't really need to get the car any higher. To pull the engine like he did you have to get under the car to undo the exhaust (nuts/bolts to main cat) and bellhousing bolts. This is plenty high to undo the PPF bolts and driveline bolts. Removing the trans with the engine is the easy way to go, try it you'll like it. It is the most beneficial for reinstallation. No screwing around with trying to line up the input shaft on the trans and then screwing around putting bellhousing bolts, starter and wiring back on.
Jeff
Old Dec 2, 2002 | 11:40 AM
Oil mod and teflon/silicon coolant seals!
Old Dec 2, 2002 | 11:55 AM
paw140's Avatar
Can someone explain to me what the oil mod is? I've seen people talk about it, but I don't understand what it is.
Old Dec 2, 2002 | 12:11 PM
nocab72's Avatar
03 Cobra Killer
To depressurize the fuel system so that when you disconnect the fuel lines you don't get squirted in the face with fuel...lol
K
