Oil pump question
Old Nov 27, 2002 | 01:50 PM
WackyRotary's Avatar
standard combustion
Oil pump question
Will a TII oil pump fit on a PRE '86 engine? I forgot if anyone has done this. I know some people use the GSL-SE pump on 12a's, but I don't know about if TII ones are compatable with the 1st generation.
Old Nov 27, 2002 | 02:00 PM
rotarygod's Avatar
Rotors still spinning
Yes they should fit just fine.
Old Nov 27, 2002 | 04:18 PM
standard combustion
Thanks for the reply. I am looking for more flow volume
Old Nov 27, 2002 | 04:39 PM
setzep's Avatar
Can I ask why? Are you running looser clearances then average?
Old Nov 27, 2002 | 05:08 PM
standard combustion
higher rpm. Seems to drop to 60psi at sustained rpm above 7500rpm(top speed run), I have a 85psi regulator. On a bridgeport so you know. And, I can get a oil pump from a TII for free if I want and I don't have access to a GSL-SE oil pump which would probably be up to the job.
Ofcourse we all know the stock gauge is not completely accurate, but I'd still like to know I have a pump capable to make the volume to keep the pressure high at high rpm were its most important. 10psi for every 1000rpm is a universal standard.
Old Nov 27, 2002 | 05:18 PM
standard combustion
Does anyone else using a 85psi regulator have any gauge issues were the pressure is a little low at times occanually?
Old Nov 27, 2002 | 11:04 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Rob @ Pineapple told me you should have 10psi of oil per 1000 rpms. You really should upgrade to the 115psi race regulator, 17.5mm oil pump, -10 braided lines and 3 window main bearings.
My 74 repu puts out 71psi at cold idle and at warm idle 30-40.
-bp-
Old Nov 28, 2002 | 01:14 AM
RotorMotorDriver's Avatar
Seven Is Coming
Wouldnt that be less than 10 PSI at an idle then? I idle at ~750-900 RPMs (depends on if the cable is sticking or not, lol), and Im sure that most people around here with stock port engines idle about the same, and we should all be getting around 30 PSI at an idle...And if it was 10 PSI for every 1000 RPMs, would that only be like 30 PSI at 3000 RPMs? So like a highway cruise at 60 (damn close to 3K RPMs) should only read 30 PSI? Im sure most people here are used to seeing around/over 60 PSI on the highway, I know I am. Somethings fishy about that to me . Im sure Rob knows his stuff, but there was some miscommunication somewhere...
~T.J.
Idle:
Highway Cruise (60 MPH):
alphawolff
Nov 17, 2015 05:57 PM
