WOT after punching it
Old Nov 19, 2002 | 09:40 PM
damn hippies
ok here is the deal... my 85 is running good again but sometimes when i lay on it ill lift to shift and my rpm's will be pinned past 8k..i know this isnt good so i turn the key off and it revs down, if i turn the key back on it will be WOT again.It takes a min. or 2 for it to go back to normal..all of the linkage moves freely i think it might be something in the car..a float sticking or something..any advice would help.
Stepdaddy
Old Nov 19, 2002 | 10:48 PM
diabolical1's Avatar
clean and inspect the throttle linkage again ... do it meticulously, and check the throttle cable for any obstructions ...
if not, then drive it to some remote area and leave it there. if it finds it's own way home, then call a priest
Old Nov 20, 2002 | 08:05 AM
damon's Avatar
Also check that your throttle return spring is in place, I had one come off and the same thing would happen.
peace
Old Nov 20, 2002 | 09:31 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
doesnt the dashpot slow the throttle return. maybe its stuck.
imitek
Oct 18, 2015 03:35 PM
matty
47
Oct 4, 2015 02:45 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
Craze8
11
Aug 14, 2015 06:11 PM
