glovebox?
Old Nov 19, 2002 | 01:09 PM
glovebox?
do your gloveboxes have a pretty big gap between the glovebox and the dash? i just fixed my glovebox latch yesterday because it wouldn't open or close properly ever since i had the car. i always thought the large gap was due the latch being broken, but now that it's fixed and closes perfectly, the gap is still there. is this normal?
Old Nov 19, 2002 | 01:18 PM
maxpesce's Avatar
Ex fd *****
Mine has a fairly substantial gap also _ I have adjusted the latch and repaired the hinges but it is still fairly wide. I also added a plastic button headed thingy (sold under the HELP brand as a TRIM RETAINER) to turn the light off, my Light switch plunger had pushed deep enough into the soft plastic of the door to cause it to not turn off the light..
Old Nov 19, 2002 | 01:25 PM
so is this large gap pretty much in all fd's?
Old Nov 19, 2002 | 01:28 PM
maxpesce's Avatar
Ex fd *****
AFIK- post up a pic so I can compare it to mine - I'll try to do the same!
Old Nov 19, 2002 | 01:46 PM
i dunno how to post pics, max. give me your e-mail and i can send it to you.
Old Nov 19, 2002 | 01:54 PM
maxpesce's Avatar
Ex fd *****
e mail is in my sig
to post pic's use the Attach File option at the bottom of the dialog box that comes up when posting w/ the POST REPLY button
Old Nov 19, 2002 | 01:58 PM
prew's Avatar
the clip on one side might be broken, one of mine is and it hangs a little lower than ussual. i cant put heavy stuff in there either.
Old Nov 19, 2002 | 03:29 PM
LAracer's Avatar
Mine ('93) has a pretty big gap that causes the glovebox light to stay on. Isn't there a TSB related to this?
Old Nov 19, 2002 | 03:43 PM
maxpesce's Avatar
Ex fd *****
Yes there is, but the TSB basically says Adjust the latch &/or replace the whole Glove Box - I will take some pic's of my fix and post them up soon.
Old Nov 19, 2002 | 04:18 PM
Decay's Avatar
Heh, I've got the same problem with my light staying on...
everyone always asks if it drains my battery
Old Nov 19, 2002 | 04:21 PM
spurvo's Avatar
don't race, don't need to
Same here. And what the hell was up with them putting the plastic doohickey over the mounting screws? Jeez, that was a hard box to get ahold of.
Ahem.
Old Nov 19, 2002 | 04:34 PM
2furious's Avatar
LORD HELP OUR COLTS!
Ya, my light is always on, too. I'm gonna take some time to rig up something cheap and ghetto to keep it off.
Old Nov 19, 2002 | 04:53 PM
maxpesce's Avatar
Ex fd *****
Its a simple fix - Go to your local Auto Parts store - get a package of HELP brand "Interior Trim Fasteners" ( the flat oval head plastic push in kind w/ the barbed shaft) select a BLACK one w/ a head about 3/8" dia, Look at the GB door there will be a small dimple where the pin of the light switch hits - drill an appropriately sized (for the fastener selected) hole at that spot, Press in the fastner (you may have to trim the shaft if it penetrates too deep, measure w/ the drill bit first) and voila' the problem is solved!
I will be taking photos soon and doing a write up on this FIX.
Old Nov 19, 2002 | 06:37 PM
what's a tsb?
Old Nov 19, 2002 | 07:00 PM
spurvo's Avatar
technical service bullitin. Also seems to be known as IIA at Mazduh dealers around the world
(ignore it always)
Old Nov 19, 2002 | 07:18 PM
RollnDrty's Avatar
i dont have pics, nor a camera but i came up with a simple fix that didnt cost me any money.... i took a small screw, about 3/4 inch in length and screwed it into the glovebox right where the small pushrod thing that activates the light makes contact with the glovebox itself... adjusted how much i screwed in the screw to make it shut off jsut right without forcing the box to stay open any further than it already does
Old Nov 20, 2002 | 01:56 AM
does this look right?
Old Nov 20, 2002 | 02:02 AM
another angle
Old Nov 20, 2002 | 02:39 AM
azndisgrace's Avatar
hahaha. i dont thinky ou have anything to worry abut there man.. mine is practically ajar compared to yours
Old Nov 20, 2002 | 07:00 AM
dubulup's Avatar
development
mine doesn't look a thing like that...'95 must be a little different.
Old Nov 20, 2002 | 07:10 AM
half past twelve's Avatar
Mine looks like yours, fdracer. My light also stays on...
Old Nov 20, 2002 | 07:36 AM
ttpowerd's Avatar
HARRRRRRRRR
Mine closes all the way and there is not a gap. I guess I got lucky
Old Nov 20, 2002 | 08:52 AM
7sweetie's Avatar
Pilots are hot!
yeah that is weird, my ex bfs fd did the same thing and it was so annoying, the light would stay on, i always wondered if it was an FD thing
Old Nov 20, 2002 | 10:21 AM
Domestic513's Avatar
Mine does the same thing too. I just took out the light bulb, the damn thing was distracting when driving at night. Plus I never have anything in the glove box anyways.
Old Nov 20, 2002 | 10:27 AM
RX7SpiritR's Avatar
The Spirit of FLUFF!
It's fine, mine looks just like that.
