What's Wrong W/ My Car?????
Old Nov 17, 2002 | 08:55 PM
yayo420's Avatar
I have an 83 RX and sometimes when I'm driving on the freeway my car will just die but i can turn the key and it will fire right back up...........WHAT THE HELL IS THIS???
Old Nov 17, 2002 | 09:52 PM
Winnipeg85GSL's Avatar
Probably the good old clogged fuel filter, when it dies are you a little more "into" the gas pedal?
Old Nov 17, 2002 | 10:13 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
Definitely replace your fuel filter as a start, because if that's what it is then in a little while you'll have to wait longer for it to start back up again after it stalls. Once you've pulled the late night half-hour walk-home, you remember to change your fuel filter every year lol.
Old Nov 17, 2002 | 10:25 PM
yayo420's Avatar
My fuel filter is brand new...........
Old Nov 17, 2002 | 10:32 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
That's odd. I guess you should make sure you don't have any vaccuum leaks, mine used to do that and I had a cracked hose on one of those accursed rats nest solenoids. Once I replaced it, the car stopped doing that. Other than that, maybe your fuel pump is dying and not supplying enough fuel at cruise?
Matt
1979 SA22C
Old Nov 17, 2002 | 11:12 PM
eddierotary's Avatar
back with rotaries
probably is the fuel pump is ready to die. that what i can think off.
Old Nov 18, 2002 | 03:37 PM
rotor vs. piston's Avatar
Function > Form
I had that problem with my SE. On my car it turned out to be a slightly lose nut on one of the coils, which ever one the tach ran off of. When that wire dosen't make great contact with the coil the computer dosen't know the car is running. Of course check all the other stuff too.
Old Nov 18, 2002 | 03:39 PM
Function > Form
Just to clearify, the emisions computer in the 12a cars controls the fuel pump.
Old Nov 18, 2002 | 05:32 PM
What you could do is take off the fuel line from the carb and route it into a bucket. Turn the key and see if there is a steady flow of fuel coming out. Quite simple to do and will tell you if its the fuel that is the problem or not.
highspeedrider
Sep 8, 2015 07:55 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
