HELP!! Stalling and no restart??
Old Nov 10, 2002 | 01:09 PM
2 hott's Avatar
Starting 2 days ago my car will stall when I am comming to a stop. Only way to get start is if I pop the clutch when I am slowing down. Once restarted only way to keep the it running is to hold my foot on the gas. If i try to restart it will turnover but will not start. Have checked vaccum lines. Engine will start when cold. Also once started if reved to over 3000 rpm has a real bad metal sound. When idleing at initial start will pull vacuum of -16 mmhg. Exhaust had a strong oil smell and is blue. I have been premixing. Last time I premixed I did not have a complette fill up only put about 6 gallons of gas since I was going to the track, but put the same amount of 2 cycle oil in. Car was fine at the track, until I got about 1 mile from my house. Engine stalls w/ A/C on or off, lights on or off. I have not done a compression check since I can't get the car to a shop on the weekend and can't keep the car running to get to the shop. My thoughts are either too much rich of a premix, or blown apex seal. Does that make sence or is there someother things to check?
Thanks in advance.
Old Nov 10, 2002 | 01:22 PM
Mahjik's Avatar
Mr. Links
You might check your "clutch switch":
https://www.rx7club.com/forum/showth...=clutch+switch
Old Nov 20, 2002 | 05:10 PM
2 hott's Avatar
Car won't start at all now! I have checked both fuel and spark. Both are good. Have gone and pulled the plugs and made sure it wasn't flooded. More help is needed!!
Coochas
44
Nov 5, 2019 11:08 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
Monsterbox
Sep 11, 2015 03:29 PM
